Old 10-17-2020, 07:14 PM
blackgoat blackgoat is offline
Default Looking for a RH Door Stainless Moulding that goes between the door,W/S 67 GTO Post
Hi ! I need the stainless moulding that goes between the top of the RH Door to the windshield Frame . It has 3 small holes for the screws. I have a 1967 GTO Post
Old 10-17-2020, 09:00 PM
BOB VIDAN BOB VIDAN is offline
Is it different than a hardtop piece? If not, I have a few for $10 and shipping.
Practicing social distancing for 65+ years
Old 10-18-2020, 09:45 AM
400 4spd.'s Avatar
I'm almost certain that the stamped screw hole locations are different. I think I have a pair so I will look at them this morning.
Old 10-18-2020, 10:47 AM
400 4spd.'s Avatar
I had no luck locating my pillar moldings.
Old 10-18-2020, 11:49 AM
Hi Bob ! It looks like there is two different ones , the one i need is with three mounting holes. The other is with 4 holes . The 3 hole one is 3/16 dia and the 4 hole ones are 5/16 dia holes. both the same length.
Thanks Larry
Old 10-18-2020, 12:04 PM
I.ve taken some post cars apart so let me look at the shop today.
Old 10-18-2020, 08:53 PM
Hi Bob ! Any luck, I can use either one. They are the same length just the number of holes, is the difference.
Larry
Old 10-18-2020, 09:56 PM
I have 1 RH, this one, has a small ding that's easy to get at. The hardtop upper and lower holes are in the same location and different in size as you stated. You could easily drill a center hole and the weatherstrip molding holder will cover it anyway. Let me know.
ID:	551738   Click image for larger version
ID:	551739   Click image for larger version
ID:	551740   Click image for larger version
ID:	551741   Click image for larger version
Old 10-19-2020, 08:52 AM
Hi Bob ! Do you have a pair of the hard top ones to , if so I will the 3 of them., you can call me if you wish. 207 649 7775
Thanks Larry
PS do you have the LH post one also ??
Old 10-19-2020, 08:33 PM
I have 3 mint LH pieces and 1 more RH with a ding, all 4 bolt type. Let me know.
Old 10-19-2020, 09:58 PM
So you have the RH One you showed me in the picture with the ding, 3 bolt by the looks as it says post on it. your left hand ones are all 4 bolt correct. If that is correct . I will take the ding one 3 hole RH and 1 4 bolt left hand. Here is my shipping info for shipping cost and I need your paypal email.
Larry Fleury
170 S Reynolds Rd
Winslow, Me 04901
207 649 7775
Old 10-20-2020, 12:00 AM
Larry, you have PM
Old 10-20-2020, 09:27 AM
Larry, you have PM
Bob ! got it all paid Pri Mail, thanks a lot . I bent my RH one when it got bent by my buffer , got it all stright and bent it again. My car is all painted, will be cut and buffed this week. engine is a 66 421 .060 balanced , 670 heads Fast EFI ,Turbo 400, vintage air, Dakota Digital gauges . It should be fun to drive again as I have had it since 1976. Last drove it in 1978.
Thanks Larry
