Old 07-20-2006, 06:04 PM
rustycarr rustycarr is offline
Default 64 tempest tail lights to 64 gto.(pictures)
ive got a 64 tempest and i want to change the tail lights to the gto look. (i know,keep the grief to a minimum) can i just remove the tempest 1/4 extensions and install gto blanks, and then intall the tail/brake lights in the rear panel like a goat? left is tempest right is gto both 64
Name:	tempest assembly.jpg
ID:	59535   Click image for larger version
Old 07-20-2006, 07:13 PM
Pecosbill's Avatar
you will need a new tail panel to accept the GTO/Lemans style tail lights. Don't know if anyone makes them repro, but Desert Valley Auto Parts (http://www.dvap.com), Bethels Goat Farm, or someone similar may have a good used one you can have welded in place.
Pecosbill
Old 07-20-2006, 09:02 PM
rzrektd rzrektd is offline
On Vacation
There was a GTO Lemans tail section on ebay a month or so back that didnt sell. Keep your eyes open as I am sure it will pop up.
Old 07-20-2006, 11:30 PM
couldnt i just cut the tempest tail panel to fit the gto lights? (slowly)
Old 07-21-2006, 07:30 AM
lil64gto lil64gto is offline
You would have to have a recessed area where the tail lights will fit into and fasten to. I am not sure if the Tempest has this recess or not, but I doubt it.
You are looking at a lot of metal fabrication if you don't plan on using the tail section of another GTO. Here is what you will need to do to get the lights to fit and sit flush.
Good luck
Jim
Old 07-21-2006, 06:17 PM
mtnxtreme1963 mtnxtreme1963 is offline
I just did this, you gotta change the tail panel, of course they're available repros for every year but ours, keep looking I got a nice clean one from one of our fellow forum memebers, post on the wanted section, good luck!
Old 08-21-2006, 03:15 AM
elefantrider's Avatar
elefantrider elefantrider is offline
don't do it! tempests are becoming rarer than gtos because of this. i actually think the tempest rear looks nicer than the gto rear. i know i'm not alone in this thinking. the gto rear end styling looks like an afterthought in my view. it's your car and you're free to do what you want but i wouldn't do it. how's that for minimum grief.
Old 08-21-2006, 11:09 AM
exhibit "A", (regrettably, also for sale)
