Old 06-13-2013, 10:14 AM
BertMac's Avatar
BertMac BertMac is offline
Default New 65 Project..The MUTANT
Thought I would post a few pics of newest project
ID:	326395   Click image for larger version
65 Mutant
1967 Firebird Fatass
70 Mutant II
I want my driveway to look like I'm stuck in the 70's!!!!
Old 06-13-2013, 10:17 AM
BertMac's Avatar
a few more
ID:	326397   Click image for larger version
ID:	326398   Click image for larger version
65 Mutant
70 Mutant II
Old 06-13-2013, 10:19 AM
BertMac's Avatar
more
ID:	326400   Click image for larger version
65 Mutant
70 Mutant II
Old 06-13-2013, 10:25 AM
BertMac's Avatar
more
ID:	326404   Click image for larger version
ID:	326405   Click image for larger version
65 Mutant
70 Mutant II
Old 06-13-2013, 10:27 AM
BertMac's Avatar
And a three run walk off home run ball my 16 year old hit in a tourney this weekend
65 Mutant
70 Mutant II
Old 06-13-2013, 12:57 PM
triathlonx13's Avatar
WOW ! Nice work !!
Old 06-13-2013, 01:04 PM
geeteeohguy's Avatar
Yes, please keep the photos coming! Is the late model GTO's floor composite with foam in the middle? Looks like it.....
Jeff
Old 06-13-2013, 02:12 PM
Keith Seymore's Avatar
Cool concept; looks like it has been and will continue to be well executed.
I look forward to seeing more.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 06-13-2013, 03:04 PM
Pontirag Pontirag is offline
now this is interesting
Old 06-13-2013, 10:30 PM
64woodwheel's Avatar
64woodwheel 64woodwheel is offline
I like how you are keeping the rocker panels original looking.
Old 06-14-2013, 09:55 PM
BertMac's Avatar
The 2004 floor is steel, it has a coating on it probably for sound deadening, that is probably what you see in the photo.
I'm currently working on getting the front end welded back together. Lots of sitting on the stool staring and thinking...
As far as the rockers, thanks, the goal is to not modify the outward looks of the 65 at all.
65 Mutant
70 Mutant II
Old 06-18-2013, 12:29 AM
BertMac's Avatar
stretching front end
ID:	326856   Click image for larger version
65 Mutant
70 Mutant II
Old 06-19-2013, 09:56 PM
BertMac's Avatar
The project is off life support (bottle jacks, jack stands, 4x4's) and back on its own 4 legs
65 Mutant
70 Mutant II
Old 06-29-2013, 08:44 PM
BertMac's Avatar
Thought I would give a little info on this project..
What I have is a 2004 GTO LS1 6 speed and a 65 Tempest body.
What I have done is start by placing the base of the 65 windshield where I wanted it on the 2004 dash. Then, with the wheelbases being different, I removed 2 1/2 inchs from the 2004 floorpan to center the rear wheels in the 65 wheelwell.
Then I moved towards the front and extended the front 7 1/4 inchs to center the front wheels in the 65 wheelwells. I was oringinally going to leave motor and tranny in original location to the firewall but with the steering rack located where it is that just wasnt going to work. so motor and tranny moved forward with the front wheels. That required cutting the shifter and extending it 7 1/4 inches to center it back in the shifter hole on the body, and entending brake lines, heater hoses and a/c lines.
One good thing about all this is with the extra engine bay room it makes the headers the easiest I have ever installed.
The wiring harness on the passenger side had to be extended...77 wires...cut two at a time and soldered a extention wire in each one..about 4 hours sitting on a stool.
I have used the 2004 power window motors..got those mounted in the doors and plan to use the 2004 power locks..just havent got to that yet.
Almost finished with fabbing up the trunk pan..
currently working on getting front fenders mounted and brackets made to support them.
65 Mutant
70 Mutant II
Old 06-29-2013, 09:56 PM
Wick's Avatar
Wick Wick is offline
Making some good progress on what will be a very cool car.
_____________________________
She woke up sunny side down and I was still thinking I was too proud to flip her over
Old 07-13-2013, 09:43 PM
BertMac's Avatar
Got the header panel and grills in today..Thanks Bob..
Spend the day fitting header panel, making brackets and making hood hinges.
At end of day it all fits pretty well. Still have some fine tuning to do. Next is to make brackets for the front bumper.
65 Mutant
70 Mutant II
Old 07-17-2013, 03:07 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
This is an awesome build !!!
Best of luck and you have earned great respect in getting this far.
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 08-06-2013, 08:29 PM
BertMac's Avatar
All major body work is done on bothe quarterpanels and one door...I so hate this stage of building a car...
65 Mutant
70 Mutant II
Old 08-08-2013, 03:25 PM
CrappieCat CrappieCat is offline
Where you at in Texas
Id like to come see this in person.
Saved from hibernation since 1979.
Old 08-21-2013, 12:52 PM
BertMac's Avatar
Still doing bodywork..priming and block sanding..
I havent liked the way the 2004 cowl rolled up to meet the 65 cowl at the wiper area..so last night I took the cut off wheel out and cut it off. after some hammering and welding here is what I wound up with. I like this better..
CrappieCat..I'm in Houston area
ID:	334105   Click image for larger version
65 Mutant
70 Mutant II
