Old 05-10-2014, 08:47 PM
6t5gto 6t5gto is offline
Default Dick Boneske restored carbs
Dick rebuilt/refinished my 65 tripower unit and did a fantastic job. He was very helpful during the process answering all my questions and concerns. I would highly recommend him if you need a tripower rebuilt. I still have to do a few things such as painting the top of the carb studs, replacing the accelerator cable etc.
ID:	363050   Click image for larger version
ID:	363051   Click image for larger version
ID:	363052   Click image for larger version
Old 05-10-2014, 09:57 PM
Dick is the best.
Knows his Tri-Powers as well as or better than anyone in the business, his work is definitely top notch.
Did a set of '64 carbs for me a few years back, they look perfect. Planning to run them on a '64 421 HO, I can't wait to try them out. My carbs are pictured below sitting on one of Dick's '65 intakes for linkage setup and adjustment before shipment.
Old 05-11-2014, 10:04 AM
michaelroy's Avatar
michaelroy michaelroy is offline
Default Carbs by Dick
Mine's purter than yours.
Name:	Mike Davis' Tripower 004.jpg
Old 05-11-2014, 10:32 AM
Tom Vaught's Avatar
Boost Engineer
Now you can run the correct 64 "Curved Linkage" system that Dick offers, and be correct for 64, B-Man.
Tom V.
Old 05-11-2014, 05:07 PM
Tom V.
Bought the parts I needed to convert to the '64 curved linkage a few weeks ago from Dick, along with a few other '64-correct parts to help dress out the engine.
Old 05-11-2014, 09:25 PM
PurplePackFan's Avatar
PurplePackFan PurplePackFan is offline
Dick also did my '66 setup that I am using on my 428. They look great and work awesome! Dick helped to re-jet them for this application and also helped me when I was having trouble getting it to idle. Turned out to be vacuum leak, not the carbs. Highly recommend his services.
John
'67 Corvette Coupe 327, Tremec 5 Spd-SOLD
2010 Camaro 2SS-Traded
2015 Z51/3LT Corvette Stingray, Laguna Blue
'67 GTO, 428, tripower, RS 600, finally done
