Old 05-12-2004, 09:27 AM
"Guy
Send a message via MSN to
How do I install crankshaft scrapper?
Who makes the best one?
Installing it with stock 68 pan and tray.
Guy
"Guy
Guy
Old 05-12-2004, 09:51 AM
KS circutguy's Avatar
Butler sells then so does Spotts Performance.
"There's nothing more unsatisfying than watching an electric car go down the dragstrip."
Old 05-12-2004, 09:52 AM
Butler sells them, as does Spotts performance.
Steve.
Old 05-12-2004, 09:57 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
as far as instalation ,when you lay the scrapper on the block and aply silicone (of your choice)make sure you leave it alone for a good 24hours overnight without touching it ,otherwise they have tendencies to leak if you move them around while it not hard yet....
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 05-12-2004, 09:59 AM
here s another
Old 05-12-2004, 10:33 AM
"Guy
how far do you install the scrapper away from the crank? .050? .100?
and do you need a spacer the same thickness on the other side to get the pan to lay flat?
Thanks for your replys!
Old 05-12-2004, 10:35 AM
"Guy
ks. nice lookin rotating assy too!
Thanks for the pictures
Old 05-12-2004, 10:37 AM
PONTIAC DUDE's Avatar
We sell em. You need around .020 for them to be effective.
You will have to trim ours to work.
Most just make the Generic ones. LOL.
You know, one size fits all.
I use just a gasket on the opposite side, plus front and rear, and Gray Ultra Seal on both sides of the scraper to block and pan.
Old 05-13-2004, 09:59 AM
Thanks, it's been "rotating " happily for 2yrs. now.Its almost daily driven.
The car runs 12's on real street tires at 106.58 @ 4,000lbs. on the motor.
Steve
bird driven to Mount St. Helens
Old 05-13-2004, 11:49 AM
"Guy
KS,
I saw pics of the your Pontiac...Rodney Red post.(I run a RR radiator too) Anyway, how much NOS are you putting to it? Looks like a Qjet plate set-up??? Thought about small shot..more for the look(yeah right)in my car. You retard the timing with MSD when on the gas? safety switch to shut down the NOS if no fuel is getting to the plate?
