Old 01-15-2023, 05:34 PM
R 70 Judge's Avatar
Default 2nd gen leaf spring suspension for drag racing
I’m in the process of upgrading my entire rear suspension on my 1970 Trans Am. I’m curious as to what is considered to be the go-to competitive leaf spring suspension set-up these days? My TA has been mid 1.4X 60’ times with air shocks and old school south side machine lift bars on a 30x12.5x15 ET Street bias-ply tire.
484” IA2 with as cast highports (around 660hp), T400, 12 bolt 3.90 gear, 10 point cage
In front I have completely updated the suspension with CPP tubular control arms, Viking hybrid double adjustable coil overs (7081COK-2A450), proforged steering rebuild kit, and I’ve added CPP hydrostop brakes, Borgeson steering box, and remote power steering to make street driving a bit more enjoyable.
So far I have Calvert split mono-leaf springs (#230-43) and I’m considering an anti-roll bar set-up and Viking double adjustable shocks.
What are the fast guys running?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 01-15-2023, 05:48 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I don't consider us fast but I would recommend the anti-roll bar. Split-mono's and Calvert bars are the hot set up along with the best shocks the budget allows.
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 01-15-2023, 05:54 PM
Steve C. Steve C. is offline
Calvert bars
Old information here:
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
Old 01-15-2023, 07:35 PM
ta man ta man is offline
Calvert split monos, Caltracs with as much shock as your budget or needs allow....I'm running the basic Calvert shock in rear works for my car.
The Following 2 Users Say Thank You to ta man For This Useful Post:
Old 01-15-2023, 10:05 PM
I meant to say CALTRACS.
https://calvertracing.com/product-categories/caltracs/
A interesting tid bit for conversation. The Calvert split mono would more often than not be a good choice if you are using their bars. It probably doesn't apply here but in a heavy car some go with a multi leaf spring.
Many years ago John Calvert was working closely with Landrum spring company, this before the introduction of their split mono spring, and they recommended a 300 rate spring on my car back then.
This was before their split mono spring and today I believe they would not recommend one that is that that stiff.
Old 01-15-2023, 11:55 PM
PAUL K's Avatar
I use the 300 rate multi-leaf spring in my red 74 Bird. They work well.
Go fast, see Elvis!
Old 01-16-2023, 11:19 AM
" I believe they would not recommend one that is that that stiff."
I might want to retract that statement regarding the use of a higher rate spring.
Sorry, that was something I presumed since reading over the years about their SPLIT MONO LEAFSPRINGS and MONO LEAFSPRINGS that are lighter.
Agree with Paul the 300 rate springs work well. I've had a 1.43 60-ft with the Landrum springs and the Caltracs bars.
The Following User Says Thank You to Steve C. For This Useful Post:
Old 01-16-2023, 02:35 PM
ejw's Avatar
ejw ejw is offline
Sent u a pm
Old 01-16-2023, 04:29 PM
R 70 Judge's Avatar
Thanks for the input guys. I’ve decided to go with the full 70-74 set-up from Funkhouser Race Cars https://www.funkhouserracecars.com/
70-74 Antiroll bars and shock relocation kit https://www.funkhouserracecars.com/p...hock-mount-kit
70-74 Leaf spring sliders https://www.funkhouserracecars.com/p...-spring-slider
70-74 Traction bar set-up (like CalTracs but larger diameter)
Longer Viking double-Adjustable shocks
Tie-down brackets
Example:
James
1970 Trans Am
Old 01-16-2023, 05:31 PM
PAUL K's Avatar
Leaf spring sliders are a good idea.
Go fast, see Elvis!
Old 01-16-2023, 06:15 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Back in the day Tri City "Launcher Springs" were GM copies of the Mopar Super Stock springs and the choice of most of the NHRA Stockers before Cal Tracs came out. My 78 TA 6o ft'd 1.51s it he them with a 10.90 time slip. I had a small 5/8" factory rear sway bar on it. They worked really good but were stiff and heavy.
The IA Camaro has Split Leaf and Cal Trac bars. Factory rear bar was too close to the 12 bolt's rear cover/brace so I used a Second Gen Pro Touring rear bar with a little longer "legs".
Not as fast yet as some of these other guys .
Skip Fix
Old 01-19-2023, 10:21 AM
BDHABT's Avatar
BDHABT BDHABT is offline
Tie-down brackets
Example:
That looks really nice.
Do you have any pics of the car off the lift?
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 01-20-2023, 03:00 PM
AllRise AllRise is offline
I went with Funkhouser set up, but am still currently under construction. The product itself though is absolutely top notch, and customer service every bit as solid. You won’t be disappointed with his quality.
The Following User Says Thank You to AllRise For This Useful Post:
Old 01-20-2023, 04:14 PM
R 70 Judge's Avatar
I'll be posting pictures of my car as it is being completed. Right now they are working on the front suspension/steering and are making a remote power steering adapter bracket so I can still have power steering when using the Stainless Headers turbo manifolds. My All Star remote power steering pump will be on the driver's side head and the alternator has been relocated to the passenger side.
James
1970 Trans Am
Old 01-20-2023, 04:21 PM
R 70 Judge's Avatar
Yeah they are great guys. I'll let them know about the positive feedback. My TA is physically in their shop getting the work done now. Don't be surprised if we have a few extra Pontiac specific parts available from them after my car is done. One for sure will be the remote power steering adapter plate.
James
1970 Trans Am
Old 01-22-2023, 01:20 PM
That is awesome! Can’t wait to see how it turns out, and what you guys come up with!
Old 03-17-2023, 12:59 AM
R 70 Judge's Avatar
Small update…
  • Calvert springs are in along with new spring perches are in
  • Funkhouser shock relocation kit is fitted and looks awesome.
  • Shocks are Viking Crusader (red eye) double adjustable and are longer than stock for additional shock travel and tuning.
  • Tie down brackets added
  • Funkhouser roller bearing sliders are in. These are very cool pieces.
  • Funkhouser custom low profile front rocker bracket
  • Funkhouser HD lower bars with HD rod ends
I’m not doing the anti-roll bar at this time. I street drive it and hope to autocross one day. Also, the trunk pan had seen better days so we replaced it while everything was out
ID:	608970   Click image for larger version
ID:	608971   Click image for larger version
ID:	608972   Click image for larger version
ID:	608973   Click image for larger version
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 03-17-2023, 01:26 AM
Scott65's Avatar
Scott65 Scott65 is offline
Nice work!
Old 03-18-2023, 09:41 PM
R 70 Judge's Avatar
These lower brackets are pretty slick. Tons of adjustment available in them plus it’s a tie down and relocates the shock.
ID:	609094   Click image for larger version
ID:	609095   Click image for larger version
James
1970 Trans Am
Old 03-18-2023, 11:53 PM
blueghoast's Avatar
Nice piece's there.
GT
