#41
had a rented spring compressor come loose on one side because the hook wasnt bent enuf. it didnt go anywhere but was some tense moments
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
#42
Borrowed the spring compressor from work seemed to work pretty well I just dont really want to do that again for a long time if ever.
#43
Been away a while but I started to collect some more parts. I found a complete 66' 4bbl intake/ex set up with all the brackets. Choke and rod are in perfect condition the heat valve spring is even in great condition. I also picked up a 66' balancer and balancer pulley. Im shipping the balancer out to be bored and the keyway recut to fit the 69' crank. Crank is at the machine shop and soon as everything is done I'll start to reassemble the engine.
#44
I located a 66-67 dual groove fan pulley, a complete 67' powersteering set up with all the brackets and alternator dual groove pulley. Special thanks to Jerry Woodland and OHCSprint67 "Ron".
