OHC-6 TECH Over Head Cam projects, questions and advice.
Old 01-07-2013, 10:23 PM
hpp's Avatar
hpp hpp is offline
Default 1966 Lemans Sprint project
Here's the start to my 66' Lemans Sprint project thread. I found the car in Hemmings magazine and had it shipped from Wy. PHS documented Sprint/auto Barrier blue Parchment interior Rally 1's still has the factory Safe-T-track rear end. Orig engine and trans are long gone. Im currently rebuilding a 69' 250 plan to use this engine set up until I find a correct '66 230 Sprint engine. I'll be running a Th-350 trans instead of the 2-speed St-300.
As some of you know I've been collecting some parts over the last few months and am still looking for some of the hard to find parts. Machine work's been done to the 250 it's bored .30 still looking for forged pistons may settle for cast pistons. So far I picked up a rebuilt 68' 1bbl head and new 1bbl cam. 4bbl intake/manifold 66' rebuilt 4bbl auto carb/Nos Sprint muffler and some other odds and ends.
Here are some pics so far removed the front end and suspension going to strip and paint the frame and bottom of the car and start doing all the body work.
Name:	1966 sprint 027.jpg
ID:	308789   Click image for larger version
Name:	1966 sprint 028.jpg
ID:	308790   Click image for larger version
ID:	308792   Click image for larger version
Name:	1966 Lemans sprint project 009.jpg
ID:	308795   Click image for larger version
Name:	1966 Lemans sprint project 013.jpg
Old 01-07-2013, 10:29 PM
hpp's Avatar
hpp hpp is offline
Some engine pics so far.
Name:	1966 Lemans sprint project 015.jpg
ID:	308803   Click image for larger version
Name:	OHC engine 001.jpg
ID:	308804   Click image for larger version
Name:	OHC engine 002.jpg
ID:	308805   Click image for larger version
Name:	OHC Carb linkage 003.jpg
Old 01-07-2013, 10:36 PM
hpp's Avatar
hpp hpp is offline
1bbl carb linkage I cut and welded for the 4bbl set up and belt cover I repaired.
Name:	Pontiac parts for sale 004.jpg
ID:	308808   Click image for larger version
Name:	4bbl throttle linkage 001.jpg
ID:	308809   Click image for larger version
Name:	More misc lemans parts 001.jpg
ID:	308810   Click image for larger version
Name:	More misc lemans parts 003.jpg
ID:	308811   Click image for larger version
Name:	More misc lemans parts 005.jpg
Old 01-08-2013, 10:17 AM
Cammer-6 Cammer-6 is offline
that lower cover was a candidate for my belt change mod before you repaired it.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-08-2013, 12:33 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Nice! I like how you figured out the brackets for the carb. Since so many are looking for that you should make a product and sell them, seriously.
Marc
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 01-08-2013, 10:20 PM
hpp's Avatar
hpp hpp is offline
Getting the frame and firewall ready for paint going to try and get it painted this weekend. Upper and lower control arms are being sand blasted going to paint those at work in the paint booth.
Old 01-10-2013, 09:49 PM
hpp's Avatar
hpp hpp is offline
Been working on the frame and firewall I used wax and grease remover in a spray bottle and a red scotch brite to scrub all the dirt and oil off. The firewall,floor pan,frame have almost zero rust and pretty much cleaned right down to the factory black. I used my da with 80 grit to sand down the frame and firewall,there were alot of factory runs in the black paint.
I found a factory chalk mark in the middle of the firewall it was actually under the black paint it's hard to see but you can almost make it out in the pic. I took some pics of the firewall were it meets the floor pan you can see where I stopped cleaning and how nice the pans are.
Name:	Frame before 1 010.jpg
ID:	309184   Click image for larger version
Name:	Frame before 1 003.jpg
ID:	309185   Click image for larger version
Name:	Frame before 1 002.jpg
ID:	309186   Click image for larger version
Name:	Frame before 1 004.jpg
ID:	309187   Click image for larger version
Name:	Frame before 1 012.jpg
Old 01-10-2013, 09:53 PM
hpp's Avatar
hpp hpp is offline
Here's a few pics of the block and the 4bbl pcv tube. The tube was pitted real bad so I ground it down and refinished it.
Name:	Frame before 1 008.jpg
ID:	309189   Click image for larger version
Name:	Frame before 1 009.jpg
Old 01-11-2013, 07:03 AM
Jeff Hamlin's Avatar
Looking good.
Nice job with that tube!
Old 01-11-2013, 12:00 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Looks good, quite a bit of progress!
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 01-13-2013, 09:52 AM
hpp's Avatar
hpp hpp is offline
Painted the frame and firewall yesterday used a paint called XO rust its enamel oil base with a satin finish,I reduced it slightly and sprayed it with my Sata spray gun. Holds up very well did my 71' T-37 over 6 yrs ago and never had a problem. Next step will be ordering the front end rebuild,installing the control arm bushings and then painting the control arms.
I wanted to mention I seam sealed the firewall prior to repainting used 3m's light bodied two part seam sealer.
Name:	Frame painted 1.JPG
ID:	309526   Click image for larger version
ID:	309527   Click image for larger version
Name:	1971 Pontiac T-37 010.jpg
Old 01-14-2013, 07:08 PM
hpp's Avatar
hpp hpp is offline
Working on the oil fill tube degreased the inside and used a bench top wire wheel to remove the rust and paint. Tommorow im going to tack weld the screen back on and the retainer.
Name:	OHC fill tube 002.jpg
ID:	309761   Click image for larger version
Name:	OHC fill tube 003.jpg
ID:	309762   Click image for larger version
Name:	OHC fill tube 004.jpg
Old 01-14-2013, 08:10 PM
I dont know what your intent is for this motor but theres alot of room for improvement on that oil fill tube/baffle/screen type evacuation system.
I made a baffle out of a couple of washers placed on an angle so the oil vapor would condense and migrate back into the pan.A copper scrubbie in-between gives it plenty of surface area for mist collection.
Old 01-14-2013, 10:00 PM
hpp's Avatar
hpp hpp is offline
Happen to have any pics of what you did? That's a good idea.
Old 01-14-2013, 11:53 PM
no installed on the 67 that was daily driver,buried in storage right now
Old 01-15-2013, 01:51 PM
Interesting. On my throw together experiment engine I simply threw the screen back into the pipe with the top folded up some.
On the washers and copper scrubbie set up, did you have any oil filling issues with flow downwards through it?
Old 01-15-2013, 02:38 PM
barrierblue66's Avatar
barrierblue66 barrierblue66 is offline
Great progress! It's gonna be a beeautiful color
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed
'66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed
My Garage
Tarheel Tigers Pontiac Club of Raleigh, NC
Old 01-15-2013, 02:41 PM
[QUOTE=TheSilverBuick;4831186]Interesting. On my throw together experiment engine I simply threw the screen back into the pipe with the top folded up some.
On the washers and copper scrubbie set up, did you have any oil filling issues with flow downwards through it?[/QUOTE
a little slower on refills
Old 01-15-2013, 06:14 PM
hpp's Avatar
hpp hpp is offline
Not sure what I was thinking last night,you cant weld aluminium screen to metal. So I used 3m panel bond to hold the screen and retainer. Just had to make sure it was bare metal to metal contact. It's rated up to around 600 degree's.
May consider something different down the road but for now I think the screen will work.
Old 01-15-2013, 07:58 PM
problem lies in design,throwing oil up thru the screen at high RPMs
