OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-12-2013, 12:08 PM
Cammer-6 Cammer-6 is offline
Originally Posted by barrierblue66 View Post
Looks like my front end - about 20 years ago when I did it The compressor I used had hooks, and I remember handling very carefully.
I normally wrap them in a blanket until its ready to install
had a rented spring compressor come loose on one side because the hook wasnt bent enuf.
it didnt go anywhere but was some tense moments
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #42
Old 03-12-2013, 10:57 PM
hpp's Avatar
hpp hpp is offline
Borrowed the spring compressor from work seemed to work pretty well I just dont really want to do that again for a long time if ever.
  #43
Old 04-20-2013, 08:10 AM
hpp's Avatar
hpp hpp is offline
Been away a while but I started to collect some more parts. I found a complete 66' 4bbl intake/ex set up with all the brackets. Choke and rod are in perfect condition the heat valve spring is even in great condition. I also picked up a 66' balancer and balancer pulley. Im shipping the balancer out to be bored and the keyway recut to fit the 69' crank. Crank is at the machine shop and soon as everything is done I'll start to reassemble the engine.
Name:	66 4bbl 001.jpg
ID:	320475   Click image for larger version
Name:	66 4bbl 007.jpg
ID:	320476   Click image for larger version
Name:	66 4bbl 005.jpg
  #44
Old 05-02-2013, 05:09 PM
hpp's Avatar
hpp hpp is offline
I located a 66-67 dual groove fan pulley, a complete 67' powersteering set up with all the brackets and alternator dual groove pulley. Special thanks to Jerry Woodland and OHCSprint67 "Ron".
