Old 09-29-2011, 08:43 AM
Tazzz2's Avatar
Tazzz2 Tazzz2 is offline
Default Check this guage cluster out!!!!
I wanted to share the new guage cluster out for my 70 Formula pro-touring SEMA car.... The cool thing here is they made the guages look stock,,,,, but they are actually autometers behind those faces.... The whole effort was to build an acurrate cluster that would work in conjunction with the Super Charged LS conversion and have fuel and oil temp guages to monitor the mechanicals when really flogging on the car in the various events we intend to run the car at..... Anyways I thought it was pretty cool and wanted to share in the excitment with you all......
Old 09-29-2011, 08:55 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Sweet!!
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 09-29-2011, 09:01 AM
The Boss's Avatar
The Boss The Boss is offline
That is nice - mounting them in the A/C openings I would assume?
And go racin' in the street.
Old 09-29-2011, 09:13 AM
njsteve's Avatar
njsteve njsteve is offline
That is awesome! I took me three double takes to see it wasnt stock.
Old 09-29-2011, 09:52 AM
Tazzz2's Avatar
Thanks guys I'm really stoked about them......
As far as the guages go,,,,,Tach, water, fuel pressure and oil temp guauges are all not stock (auto meter),,, and yes I'll be using the air vents Boss....
Old 09-29-2011, 10:11 AM
SD73's Avatar
SD73 SD73 is offline
That is way too cool! Make sure to post a pic with them installed.
Old 09-29-2011, 10:41 AM
Tazzz2's Avatar
Sure I'll post some pic's wen they install the dash in the car.....
Old 09-29-2011, 11:03 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Nice, Albert!!!
Regards,
"455HO" Lloyd
Old 09-29-2011, 12:05 PM
Norwood's Avatar
Norwood Norwood is offline
Albert you are the BOMB
Old 09-29-2011, 04:55 PM
70UglyBird 70UglyBird is offline
That is freaking cool!
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
Old 09-29-2011, 05:18 PM
Tazzz2's Avatar
Thanks guys I feel like the kid in the candy shop and can't wait to get it together.....
Old 09-29-2011, 05:44 PM
cnc's Avatar
cnc cnc is offline
Albert ya never cease to amaze me with the stuff your doin....wow....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-29-2011, 06:20 PM
Tazzz2's Avatar
Thanks bud
Old 09-29-2011, 06:36 PM
LeighP's Avatar
LeighP LeighP is offline
That is truly sweet! I had to read the faces to see they weren't original....too cool!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 09-29-2011, 07:06 PM
Yeah I am SERIOUSLY rethinking my Covan panel with Speedhut gauge plan now that I know this is possible. The stock gauges are beautiful and the fact you have the look with the function of autometer is really cool.
This is probably one of my favorite Firebird builds to follow. Hell I might even go to SEMA this year to check it out in person...
Old 09-29-2011, 07:57 PM
Those are pretty cool.
1974 Formula 400 - Ram Air automatic
Old 09-29-2011, 08:23 PM
Tazzz2's Avatar
Thanks guys we're doing the thrash and it's real exciting when we get results liek this coming together for the build......
70 UglyBird, come on out bud I'll take you for a blast in it Pal.....
Old 09-29-2011, 08:37 PM
Wow that would be sweet! Course after a ride in yours I'm thinking mine would seem woefully inadequate. Would be nice to know the potential of those trick parts!
Old 09-29-2011, 08:41 PM
Tazzz2's Avatar
Only one way to know the potential of those parts,,,,, thrash the car dude ;-) and I'm sure your car is killer too but thanks bud...
Old 09-30-2011, 05:28 PM
PONTIAC-ONE's Avatar
PONTIAC-ONE PONTIAC-ONE is offline
Very nice, it's going to be one great Bird!
That fuel press & oil temp is just what I need... can they make more, contact info?
I would need lower fuel press numbers/readings for a carbureted engine, that's nice stuff, I'm surprised nobody's making something like that for the catalog parts sellers.
2 sons, 2 Firebirds. 1971 Formula 455, 1972/w 455 HO added.
1974 Formula 400 "retired", parts car now.
