Old 12-04-2019, 02:37 AM
yellow1098's Avatar
yellow1098 yellow1098 is offline
Default Butler Facebook feature (first post)
Thought this Butler feature would be a good first to show you guys what I'm working with ....my goal is 650-700 hp ....so I'm figuring out my head choices to get there...what do you recommend? What should I know before I buy or little things I should do first....Also was thinking of a custom cam grind and wanted suggestions for that as well....thanks everyone nice to meet ya
Greg
https://www.facebook.com/15348679768...83?d=n&sfns=mo
Old 12-04-2019, 07:51 PM
pastry_chef's Avatar
Do you have a block now?
I'd go with ported high ports but other heads would get you there.
Old 12-04-2019, 08:35 PM
AG's Avatar
AG AG is offline
A 461 with a forged rotating , 340+cfm heads, Northwind/1000 cfm carb or Victor/Dominator and a solid roller cam similar in size to my race cam and you will be there. You will need billet 4 bolt caps if you use a stock block.
Old 12-04-2019, 11:18 PM
ponyakr's Avatar
ponyakr ponyakr is offline
A member here built a stock block 4.5" stroker, with unported High Ports, Northwind, 1050 Dominator, and a solid roller. It made 755hp @ 5900 rpm, on E85.
Old 12-05-2019, 02:47 AM
yellow1098's Avatar
I have a 70 4 bolt main block with billet 4 bolt main caps.....for the fuel system I'm running a Holley super sniper .....I will definitely be going with a solid roller cam....tell me alittle more about the highports...I got a good quote from KRE but Butler suggested there 340 CNC eheads....and they did feature me haha
Old 12-05-2019, 03:39 AM
Stripes's Avatar
Stripes Stripes is offline
Butler built our 461 with thier hydraulic roller 600hp cam, 340cfm round port e heads, northwind, fast efi, and Doug's headers. 600hp, 600tq.
Old 12-05-2019, 08:56 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Biggest concern with the high ports is they raise the intake manifold about an inch and make it nearly impossible to fit a good induction system under a factory F-body hood.
Go fast, see Elvis!
Old 12-05-2019, 10:17 AM
AG's Avatar
AG AG is offline
Is that your motor in the Butler facebook feature? Is it already built?
Old 12-05-2019, 04:01 PM
yellow1098's Avatar
[QUOTE=Stripes;6087796]Butler built our 461 with thier hydraulic roller 600hp cam, 340cfm round port e heads, northwind, fast efi, and Doug's headers. 600hp, 600tq.[/
That sounds great might try to pull alittle more with a soild roller vs the hydraulic....what are the advantages of going that way?
Old 12-05-2019, 04:02 PM
yellow1098's Avatar
I was worried about how to go about that with my shaker...I do have a drop base shaker from PTFB
Old 12-05-2019, 04:04 PM
yellow1098's Avatar
The motor you see in the car is my current motor....first gen eheads with low compression pistons .....the motor we are discussing is the new 461 you see on the engine stand pic....the shortblock is completed on a stand waiting on the top end
Old 12-05-2019, 04:17 PM
Stripes's Avatar
The cam in mine is mild for a 461; 242/248@50 with 540/563 lift with 1.5 rockers. Likely the next cam, 248/254 would get you pretty close to your goals. Remember identical cams specs, with one being a hydraulic roller and one a solid, the solid has less effective lift and duration due to valve lash. Butler thought at 600hp the hydraulics were the way to go, I didn't argue. I was trying to have enough vacuum at idle to operate vacuum brakes, and the cam we selected, it is still marginal. (haven't install engine yet) More cam and power brakes need to evolve to hydraulic boosted set up off your power steering pump.
Old 12-05-2019, 07:09 PM
Navy Horn 16 Navy Horn 16 is offline
If you are going to do all forged stuff anyway, just build it to take a 200 shot and go with a cam that you don't have to run a vacuum pump with. That pump and pully is going to eat power all the time.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning.
Old 12-07-2019, 12:56 PM
yellow1098's Avatar
The shortblock is all completed and it is all forged ....it can take a 200 shot right now...so I'm good there....I already have the vacuum pump installed on my current motor in the car because of blowby.....
ID:	526213   Click image for larger version
ID:	526214   Click image for larger version
Old 12-07-2019, 04:07 PM
92GTA's Avatar
92GTA 92GTA is offline
You run a vacuum pump on a daily driver? What are you rebuild intervals for the pump? This has been the one thing holding me back from doing this...
1969 Pontiac Firebird
Old 12-08-2019, 02:40 AM
yellow1098's Avatar
I wouldn't say it's a daily driver...but I drive it a few times a week with weather permitting....I have had it about 6 months and not that many miles on it but I haven't rebuilt it or needed to as of yet...I got it from butler....if you have any leak or blow by issue you won't any more with one of these
The Following User Says Thank You to yellow1098 For This Useful Post:
