Old 06-20-2014, 01:00 PM
xkeots's Avatar
xkeots xkeots is offline
Default 67 GTO Frozen manifold Bolts Removal Help
I have one center bolt on each side of my exhaust manifolds on my 67 GTO 400 Motor that I cannot remove. I bought an broken bolt/head extractor kit but all it did was shave the metal on the head and not grab it.
The points of the heads are rounded now on both.
Should I
#1 heat the bolt?
#2 Hand file the flat spots so I can get a boxed or a socket on it?
#3 MIG weld a new nut on top of the old head then get my oxy/aceteline and heat the bolt and smack it with a hammer to loosen the rust on the threads?. I wish I could get Kroil or PB in there.
I do not want to snap the bolt.
All the others came out with a little back and forth play.
Any suggestions wanted.
Jax
1967 GTO Convertible.
Old 06-20-2014, 02:25 PM
Andre's Avatar
Andre Andre is offline
Whichever method you choose, I have found that applying clockwise torque first, will often make it turn easier when your try to turn it counterclockwise. I learned this from the old school guys.
Old 06-20-2014, 03:42 PM
GT182's Avatar
GT182 GT182 is offline
Run the engine and get the manifolds and heads hot, or use a torch to heat them after you mig weld a nut to the bolts or file them to get a socket on them.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 06-20-2014, 05:05 PM
This works a lot. I also found that a good penetrating oil sprayed on many many times over they course of a couple of days works too. When we took off the old exhaust manifold off my old motor, I did this over the course of a week and they all came off with ease.
Old 06-20-2014, 07:37 PM
carcrazy carcrazy is offline
If you can get at them you can also tap with a hammer. This will sometimes loosen them up enough. If that doesn't help break out the torch (very carefully).
Old 06-22-2014, 07:31 PM
jd66 jd66 is offline
If you access to an oxygen- acetylene torch cut the head off the bolt and pull the manifold back , usually the bolts come right out of the heads then. jd grim 66 gto
Old 06-22-2014, 08:40 PM
GT182's Avatar
Don't try and remove them with cold heads. Get the engine up to temperature first and work the bolts back and forth to free them up. When you put it back together, use never seize on the bolts so you don't have the same problem later on..... if you need to pull the manifolds again.
Gary
Old 06-23-2014, 07:11 AM
1966geeto 1966geeto is offline
I would try option 3 if you think you can get another nut welded to it if not follow JD's advice you should be able to drop the manifold and gain access to the stud heat it up after soaking it try reverse rotation first then back it out I have had success getting the manifold as far away from the head as you can the cut the bolt flush with the manifold nut the head the manifold should come out leaving you an inch or so of stud left to work with.
Old 06-23-2014, 07:00 PM
67ramairowner 67ramairowner is offline
If you can get it moving clockwise even a bit try alternating clockwise counterclockwise clockwise. Increase the number of degrees you rotate the bolt with each clockwise, counterclockwise, clockwise cycle. Once it starts to move it gets easier..breaking the grip on the treads that is now locking things up is the start.
Old 06-23-2014, 10:55 PM
The heads rust to the manifold not the bolts to the head. If you can get the heads off the manifolds will come right off and the bolts will unscrew like jd66 said.
Old 06-25-2014, 12:04 PM
JohnS66GTO JohnS66GTO is offline
Could be rusted to one or both. I've had very good luck smacking the top of the bolt head with a ball-peen hammer a few (or more) times before putting torque on them. Taken out many exhaust manifold bolts this way that the "experts" said would never come out without a torch or breakage.
Take your time, be patient, and walk away for a while if you're getting frustrated. Do everything you can to keep from twisting them off. I feel your pain... and wish you luck.
John
1966 GTO Post Coupe, Barrier Blue / Parchment, 4-speed, A/C
1988 Fiero GT, T-tops, 5-speed, 3.4L engine swap
