Old 06-12-2020, 05:44 PM
vertigto's Avatar
vertigto vertigto is offline
Originally Posted by ZeGermanHam View Post
Viking coilovers aren't going to have superior damping compared to a quality shock from Bilstein or Koni, though. I vote to keep it simple and dial it in using a traditional setup, and use the money saved elsewhere.
Yep...could use the money elsewhere.
Thought about setting down some wood (like you said), in the event that clearance is a problem. Can angle into/out of the driveway also. Maybe I just bite the bullet and get the 2" drop package with the Bilstein B6 HDs.
I guess I like thinking out loud.
Just wait until I start a engine/tranny rebuild thread. I'm sure there are a ton more opinions.
  #42
Old 06-12-2020, 08:43 PM
Andretti's Avatar
Andretti Andretti is offline
Thumbs up
Originally Posted by Bob's GTO View Post
Let me know if you want suspension details.
That looks sweet! Love the stance and look with the 18" Bandits. Are you running a staggered set-up, 40 series or 35's?
  #43
Old 06-12-2020, 08:45 PM
Andretti's Avatar
Front: 18X8 - 235/40
Rear: 18X9 - 275/40
Sorry, didn't finish reading this tread!
  #44
Old 06-16-2020, 08:40 PM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
I went from Bilstein to coil over and never noticed any negative affects on dampening, in fact the coil overs have two different dampening knobs to play with, you get to dial in the feel you like or require.
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
  #45
Old 12-29-2020, 12:40 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
So... what did you go with?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
  #46
Old 12-29-2020, 05:37 PM
vertigto's Avatar
BMR upper/lower A-arms with tall ball joints (Delrin/poly) and Viking coil-overs with 18" US Mags Ramblers and Nitto 555 (245/45 & 275/40) and rear adjustable upper control arms (BMR) with a UMI rear shock tower brace. PST poly body mounts and bushings.
  #47
Old 04-18-2022, 12:18 PM
newmarket newmarket is offline
Hey I have a 1970 Gold GTO too, prior to going with your setup did you consider doing something like this below?
https://www.umiperformance.com/home/...-2-5-coilover/
  #48
Old 04-18-2022, 03:36 PM
vertigto's Avatar
I'm not sure if I was aware of that UMI setup, but don't remember spending near $3900 for what I did. IIRC...it was more like $2500 for everything.
  #49
Old 04-19-2022, 08:38 AM
I reached out to BMR last night to see if they can quote on the equivalent setup. I have drums in the front and will have to convert to disc (which is a good thing). I read through some of your posts and didn't see who you went with, do you mind sharing?
I'm in Canada too, near Toronto.
Adam
  #50
Old 04-19-2022, 10:13 AM
vertigto's Avatar
I went with Right Stuff's Big Brake conversion kit (had OE disc brakes in the front). Call Ed Stahurski at Right Stuff and he'll guide you, if you want to go that route.
ID:	588958   Click image for larger version
