Old 10-06-2023, 01:31 PM
Tempest's Avatar
Tempest Tempest is offline
Default 1958 Canadian Pontiac
Hi Guys,
These pics are from a 1958 Canadian Pontiac.
I understand that the suspension components are different between Pontiacs and Chevs, however, I also know that Canadian Pontiacs used Chev drivetrains.
Can anyone tell me if this is a Pontiac engine and suspension? or is it Chev? I think its all Chev?
Thanks for your help
ID:	621165   Click image for larger version
ID:	621166   Click image for larger version
Old 10-06-2023, 02:02 PM
Chevy drivetrain and chassis under those cars.
That’s a Chevy 235 six in your pictures.
Old 10-06-2023, 02:22 PM
Tempest's Avatar
That is what I thought.
Thanks B-Man
Old 10-06-2023, 03:31 PM
Stuart's Avatar
Stuart Stuart is offline
It was a Chevy six but they used the 261ci version. You can see a 1958 Canadian Pontiac brochure here: https://oldcarbrochures.org/Canada/G...ure/index.html
Old 10-06-2023, 03:41 PM
Tempest's Avatar
Thanks Stuart
Old 10-06-2023, 03:51 PM
My bad.
I at first thought 261 but the 4 bolt valve cover threw me off. All the ‘54 -‘62 235 & 261 sixes have the 4-bolt valve cover, the earlier engines had 2 long studs in the center retaining it.
Old 10-10-2023, 02:01 AM
Carl S Carl S is offline
Unless it's been changed I believe it should have been built with a 261. I don't think any 58 Canadian Pontiacs came with a 235.
Old 10-11-2023, 11:10 AM
Tempest's Avatar
Thanks Carl,
I'm not too concerned about the driveline, but I understand that the suspension components are different between Chev and Pontiac, and want to be sure I order the correct parts for this car. (steering, suspension )
I believe I need to order 1958 Chev parts, for this Pontiac.
