Old 10-18-2010, 01:30 PM
schlitzman's Avatar
schlitzman schlitzman is offline
Default '67 GP Transmission questions
Hi All,
I have two additional questions about my recently acquired '67 GP auto transmission convertible.
Where is the trans connection for the kick-down switch? and where is the back-up light connection?
My first classic Pontiac auto transmission car and I'm not sure where these connections are located. Nay help will be most appreciated.
Bruce
Old 10-18-2010, 02:20 PM
Stuart's Avatar
Stuart Stuart is offline
The kickdown switch is on the carburetor, I believe. the backup light switch is typically on the steering column under the dash on automatic cars with a column shift, but since this is a GP I imagine it has a floor shift and console? If that's the case the switch is probably under the console on the shifter linkage.
Old 10-18-2010, 03:03 PM
stevep's Avatar
stevep stevep is offline
The kickdown switch is on the gas pedal linkage bracket, which bolts to the firewall with 2 bolts on a 67.
The backup/neutral switch is on the shifter under the console plate.
Old 10-18-2010, 03:43 PM
Coach's Avatar
Coach Coach is offline
+1 at least on my 400 / auto 67 GP
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
Old 10-19-2010, 03:46 PM
68Prix's Avatar
68Prix 68Prix is offline
I agree the kickdown switch is on the gas pedal linkage bracket, and the back up light switch is on the shifter under the console. If it is a rare column shift car it would be under the dash on or near the column.
Old 10-19-2010, 06:09 PM
schlitzman's Avatar
Thanks all,
Yes, I have the kick down switch under the accelerator pedal. It is not connected at all, terminals are exposed. Where do the connections go to? Some place on the transmission?
Bruce
Old 10-19-2010, 06:27 PM
stevep's Avatar
You should have 12 volts going to the switch with the key on and when you floor the gas, 12 volts should come out the other terminal and go to the spade connector on the driver's side of the trans, above the pan.
Put the gas pedal to the floor to see if it actuates the switch. We had a 67 Executive that had no kickdown. When we floored the throttle, it didn't even come close to operating the switch. A little tweaking worked wonders.
Old 10-20-2010, 08:12 AM
schlitzman's Avatar
Many thanks, Stevep.
I'll get to your recommendations this weekend. You gave me exactly what I needed. Let you know how I make out.
This Forum is simply great, with helpful, great folks.
Bruce
Old 11-07-2010, 11:34 AM
schlitzman's Avatar
Thanks to all for the very helpful info. I connected the kick down switch to the trans solenoid on Tuesday. Wow!!! What a difference in performance and driveability. Feels like a rocket ship now. Really makes the 428 come alive.
I'll get to the B/U light switch over the Thansgiving holiday--- pesky work keeps getting in the way.
Thanks much again.
Schlitzman
