Old 04-10-2020, 04:41 PM
fyrffytr1's Avatar
Default How many here does this apply to?
It fits me to a T.
Name:	Screenshot_2020-04-10 Facebook.jpg
The Following User Says Thank You to fyrffytr1 For This Useful Post:
Old 04-10-2020, 04:53 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default me too
Thats perfect,lol.How true it is.
Old 04-10-2020, 04:56 PM
dataway's Avatar
dataway dataway is offline
I must be special ... I actually manage about 10% cleaning
Old 04-10-2020, 05:10 PM
vertigto's Avatar
vertigto vertigto is offline
I am a little retentive and try to keep everything organized. Otherwise I forget where I put things.
Old 04-10-2020, 05:12 PM
Me too. Been out there for three day's. Son say's it still looks the same. Anybody need a set of piston and rods for a 1981 Dodge 2.2L new ? Seem to not get rid of anything just relocating to a different part of the garage
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 04-10-2020, 05:38 PM
242177P's Avatar
242177P 242177P is offline
I've found stuff I forgot I ever had, it's like getting things for free!
The Following User Says Thank You to 242177P For This Useful Post:
Old 04-10-2020, 05:42 PM
cnc's Avatar
cnc cnc is offline
Yep all true
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 04-10-2020, 06:47 PM
gtohunter's Avatar
gtohunter gtohunter is offline
Got a bad habit of saving spark plugs removed doing tune ups over the last 5 decades. Will never ever use any of them, but I got a bucket of them just in case!
Jimmy M
68 GTO
The Following User Says Thank You to gtohunter For This Useful Post:
Old 04-10-2020, 07:36 PM
64speed's Avatar
64speed 64speed is offline
I have realized that I am missing something every garage should have. A coffee can full of random bolts. I have been playing with my stuff. Painting my calipers. Cleaning tools. That sorta thing
The Following User Says Thank You to 64speed For This Useful Post:
Old 04-10-2020, 07:51 PM
Definitely applies to me. I told my wife that after finding all of my hand tools I shouldn’t have to buy any for the next 10 years. I discovered I own 5 10mm sockets.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 04-10-2020, 08:03 PM
67drake's Avatar
67drake 67drake is offline
Guilty
13.95 @ 102.1 on street tires @ 4055lbs.
Old 04-10-2020, 08:42 PM
SRR's Avatar
SRR SRR is offline
Default Oh boy!
I have a wooden crate under one of my rolling benches that has a crate full of bolts removed over the last 3 decades that's splitting apart at the seams, plus several coffee cans full. My wife says I'm a hoarder. I disagree, hoarders save junk that isn't useful.
― Calvin Coolidge
The Following User Says Thank You to SRR For This Useful Post:
Old 04-10-2020, 10:08 PM
fyrffytr1's Avatar
I sorted all my nuts, bolts, screws and washers into different cans. I have a tub for electrical and misc. When I need a bolt or nut I go to the store and buy a pack. Easier than dumping the can on the counter and going through the pile. Plus, the leftovers from the pack get to go into the can for future non-use!
The Following 3 Users Say Thank You to fyrffytr1 For This Useful Post:
Old 04-10-2020, 10:26 PM
tooski tooski is offline
I also have cans of fasteners. But I spend way more time searching through them than it would take to buy new. I usually find about one or two less than what I need and end up going to the store anyway. And when/if I find the amount I need, I spend the same amount of time cleaning them up for use.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 04-10-2020, 10:30 PM
carcrazy carcrazy is offline
It certainly applies to me!
T.Weber's Avatar
T.Weber T.Weber is online now
Yep,
Guilty as charged.
Old 04-10-2020, 11:37 PM
71HO4SPD 71HO4SPD is offline
Sounds like my two year old when I tell him put his toys up for the night.
Old 04-11-2020, 01:07 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Well at least I'm not the only one. And I agree- nobody could see any difference in the garage. But I am stimulating the economy, by buying parts to resurrect some "found" items (like the circular saw I built in shop class in 1957).
Old 04-11-2020, 01:09 AM
dataway's Avatar
I have a set of Metric and Standard thread checkers ... the kind on a cable you screw the bolt into on one side and thread a nut on the other side ... if I'm really bored I go down at night, listen to crazy people on late night AM radio and sort through the used bolts and put them in their labeled drawers.
Old 04-11-2020, 03:00 AM
Drag Star Le Mans's Avatar
I was doing this today, even throwing some junk away.
DragStarLeMans
