OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-10-2021, 01:38 PM
neill neill is offline
Default Valve stem installed height
Hi all, just got my head back from the machine shop and I just want to do a quick check to make sure the stems are at the correct height but I can’t find the specifications anywhere. Does anyone have this info close by? Thanks in advance , Neill
69 Firebird, 462 turbo 400 3000 stall, 8.5 323 rear
Old 04-10-2021, 09:40 PM
Jeff Hamlin's Avatar
Arrow
Old 04-11-2021, 11:12 AM
Thanks Jeff, I will go over all that this morning
Old 04-11-2021, 12:59 PM
Bill Hanlon's Avatar
Great info, but Jeff (or whoever he got it from) misplaced a digit. The first number in the red line should be 0.850", not 0.085"
Old 04-11-2021, 02:52 PM
Thumbs up
Thanks for the catch.
Corrected;
Old 04-15-2021, 12:09 AM
When you say that you diamond lap the followers, do you mean that you use a lapping compound on the hardened surface that rides on the cam? Do you also do the other contact points? Do you use a lapping stone or any flat surface? I may be pulling my cam housing back off due to second guessing myself about oil passages and the gasket possibly not being lined up properly. If I do i will try dressing the followers as you suggest.
The valve tips were all at .840 with 3 being an additional .004 to .008 thousandths shorter. I'm hoping that as the valve job breaks in the stems will grow a little. Neill
Old 04-15-2021, 06:41 AM
IIRC This outline was written by Richard McDonough so not sure how he does his.
In the past, my local machine shop did any I needed.
You might reach out to Rob he now owns/runs Woodland Sports and should have any/all related info on this process.
https://www.facebook.com/Woodland-Mo...location=group
Old 04-16-2021, 12:08 AM
Okay, thanks again Jeff. I did buy a few pieces from Rob already so I may talk to him again.
Old 02-22-2022, 11:24 AM
63 bomb's Avatar
63 bomb 63 bomb is offline
Hey Jeff, it seems that whatever you posted in post # 2 is no longer there. Can you re-post the measurements and possibly how to measure the valve stem height? Thank you!
Old 02-23-2022, 07:20 AM
Thumbs up
Old 02-23-2022, 10:56 AM
63 bomb's Avatar
Thank you Jeff. Is that .850" measured from the plane that the cam cover bolts to up to the top of the valve stem?
Old 02-23-2022, 07:32 PM
Hokie1984 Hokie1984 is offline
Yes. It sounds easier than it seems. I remember using feeler gauges, micrometer and straight edges. I also remember using some basic geometry to get the measurement. PITA. Towards the end it was more of a go no go confirmation. Maybe Jeff has some tricks.
Old 02-24-2022, 06:50 AM
Old 02-24-2022, 10:57 AM
63 bomb's Avatar
Great info, thank you very much! I'm guessing this measurement would also change with a valve that has tuliped in the head effectively lengthening the valve stem? Still not sure what the full issue is with mine, been too cold here to pull it apart. But, having this info will no doubt lead me down the right path. Thanks again!
Old 02-24-2022, 11:15 AM
When I did mine, like 8 of the 12 were all right in the middle. 2 were like 5 thousands off and 2 were on the ragged edge, just barely in spec. If I do it again, I will make up a T square equal to the bottom tolerance. Then use a feeler gauge to see how far off the bottom I sit. The biggest issue was I needed like 4 hands to hold everything in place while I measured.
