OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-11-2021, 11:40 PM
PepinoBBB PepinoBBB is offline
Default OHC Sprint head
Hi Guys,
By any chance anyone knows if the cylinder heads seats for the valves need to be replaced for modern gas using hardened seats and are those seats regular seats or are they special ones. The machine shop said the seats are to big and the head metal walls to thin. The machine shop has strong chevy 50's 6 in line experience. Thank you guys your help is greatly appreciated.
Old 04-12-2021, 06:59 AM
Jeff Hamlin's Avatar
Exclamation
It's about a 50/50 split on those who have and those who have not.
I had my head serviced 2 years ago and we didn't see the need.
I've personally had never done it on any of my engines.
Just addressed the guides and seals.
Most indicate the Exhaust valves are the ones that they have added seats to.
Reach out to ROB he should have some good information on this;
https://www.facebook.com/Woodland-Mo...location=group
Name:	OVERHAUL 21 (1).jpg
ID:	564574   Click image for larger version
Name:	OVERHAUL 21 (2).jpg
ID:	564575   Click image for larger version
Name:	OVERHAUL 21 (3).jpg
ID:	564576   Click image for larger version
Name:	OVERHAUL 21 (4).jpg
Old 04-12-2021, 10:10 AM
694.1 694.1 is offline
If you are running dual springs on a Sprint & doing a good deal of highway driving with 3.23 of higher gears, I can recommend it.
Stiff springs & high rpms are what causes the damage. Of course I have since learned to shift before 5500 rpm!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 04-12-2021, 07:46 PM
Hokie1984 Hokie1984 is offline
I did exactly what Jeff said, address the guides and seals. I asked the machine shop and they basically said if I was going to pull a trailer on the highway then get it done, if not don’t worry about it.
Old 04-18-2021, 11:16 PM
Hi Guys , Thank you all for your input and advise. Really appreciated.
