Old 08-22-2021, 05:10 PM
dataway's Avatar
dataway dataway is offline
Default Aerosol Verdoro Green touch up paint
Who do you guys recommend for a rattle can of Verdoro Green paint?
I just want something for doing bolt heads and detailing work. Preferably single stage, gloss acrylic enamel or lacquer.
Old 08-22-2021, 05:46 PM
Jeff Hamlin's Avatar
In the 4 different times, I've called on them their match was spot on.
I just bought a paint pen for my '66 and again right on. Perfect for little knicks.
https://www.automotivetouchup.com/to...68/all-models/
Old 08-22-2021, 06:59 PM
dataway's Avatar
I'm a bit confused by their site ... says it's a bc/cc system. I was hoping for a basic single stage gloss.
Old 08-22-2021, 09:23 PM
1965gp 1965gp is offline
If you go through the order process they offer spray cans. I just ordered some Atoll blue touch up for my 70 GTO after seeing this.
Old 08-23-2021, 01:18 AM
dataway's Avatar
I went through the order process and it wanted me to add a can of clear coat. If they are really selling basecoat clearcoat then the base is not gloss. I didn't order because I can't tell if the base is actually a stand alone gloss paint.
Old 08-23-2021, 05:18 AM
Exclamation
It is a base coat, You don't have to purchase the Clear.
Old 08-23-2021, 08:55 AM
TAKerry TAKerry is offline
I highly recommend automotive touch up. They sell from paint pens to gallons. I painted my car with paint from them and have been very pleased. I had some untouched original spots and the colour match was without exaggeration PERFECT. As far as bc/cc, yes the spray cans (and maybe all of their stuff) is a base coat paint. When you spray out of the can it will be flat. You then spray a clear coat over the top for the shine. Its really not too big of a deal. I have used their spray cans on hidden spots. If you have any questions give them a call. I did that when I was ordering by the gallon and they were more than helpful to talk to. You can either buy their clear in a spray bomb or use your own clear. For my car I used S/W clear and it worked just fine.
The Following User Says Thank You to TAKerry For This Useful Post:
Old 08-23-2021, 11:29 AM
78w72 78w72 is offline
check with your local auto paint stores, they can usually mix up any type of paint you want (single stage enamel) in a can. ive had my local sherwin williams auto paint store put single stage in a can for about $30.
keep in mind any new paint probably wont be a perfect match to older paint thats been sun faded, but for small items like you mention it shouldnt be an issue.
Old 08-23-2021, 02:00 PM
dataway's Avatar
Last night I used some old PPG Verdoro Green I had left over from 20 years ago, basic acrylic enamel SS. Seemed to work fine ... but a pain to mix up a tiny batch for the gun.
Yes, this isn't for any kind of exterior touchup, just for the odd nut, bolt, bracket etc. that I might miss during the painting process.
