Fuel Senders
Is there anyone selling a proper 0-30 ohm, two line ( 1/4 and 3/8) fuel sender for a 68 A body?
Host only seems to carry 0-90 ohm with reversed fuel connections. |
Well if you get a precision 42 ohm 1% 2 watt resistor and wire it in parallel with the sender then you will have a 28.63 ohm sender.
Then it’s on to the fuel connection issues!
The Following User Says Thank You to steve25 For This Useful Post: | ||
I do believe that 68 should have a 0-90 ohm sending unit.
Thinking mid 60's wagons were the last to use 0-30 ohm sending units. Clay |
The Following 2 Users Say Thank You to "QUICK-SILVER" For This Useful Post: | ||
Agree, I believe my 64 GTO was the last year or next to last year to use the 30 ohm
fuel sender. All of the later GTOs should be the 90 ohm sender. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
Thank you gents.
Any thoughts on best brand? |
I just put an oriellys stainless unit in a 68 and it reads purrrrrrrfectly
The Following User Says Thank You to Scott Thelander For This Useful Post: | ||
Funny you should ask. I just rebuilt/cleaned my sending unit. And yes it is 0-90 ohms.
Mine came out a very clean tank but was reading infinity. I opened the resistor unit and soaked it in carb cleaner for awhile. I then ran a piece of 200 grit across the windings and polished the movable contact. I also tighten up the terminals. Reassembled and it works like brand new.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
The Following User Says Thank You to OG68 For This Useful Post: | ||
Unfortunately mine is long gone.
I'll look into the O'rielly's. |
Ordered one from our gracious hosts. Thank you.
Fuel gauge sender
If I remember correctly 64 was the last year the 0-30 ohm sender was used.
The Following User Says Thank You to AC445 For This Useful Post: | ||
