Old 09-19-2021, 07:58 PM
64speed's Avatar
64speed 64speed is offline
Default 1964 Radio
Does anyone have any pictures of where the bracket mounts and how it mounts in the dash? My car had no radio and all I have is this radio and this bracket with no idea what to do.
Old 09-20-2021, 01:37 PM
Jack P. Jack P. is offline
You should have a small L shaped bracket that screws from the radio in the back to the bottom section of the steel dash. Trying to load a pic.
Old 09-20-2021, 02:17 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The radio support bracket is more of a Z shape.
This bracket supports the weight of these radios.
First photo is my ‘66 showing how it mounts.
Other photos show there is a difference in the length of these brackets.
ID:	573457   Click image for larger version
ID:	573458   Click image for larger version
ID:	573459   Click image for larger version
ID:	573460   Click image for larger version
Old 09-20-2021, 05:31 PM
Tom Vaught's Avatar
Boost Engineer
Great Info, Thanks 60stuff.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 09-20-2021, 07:56 PM
64speed's Avatar
Yes thank you
