Closed Thread
Old 07-04-2020, 02:28 PM
GTOGEORGE's Avatar
So 5 passes in 95 degree weather and it hasn’t missed a beat.
GTO George
  #162
Old 07-04-2020, 02:35 PM
GTOGEORGE's Avatar
So long story I had my carbs redone by APD and they came back with 182 jets in them, I talked to them and they said it was a good starting point, we’ll I thought that 182 isn’t enough jet so I installed what I had in the other carbs 212. Didn’t get a chance to pull plus plug do this last time run today I went to 200 and ran the same mph as yesterday.....any thoughts? Just curious.
GTO George
  #163
Old 07-04-2020, 04:24 PM
GTOGEORGE's Avatar
Well damn........got my butt kick first round in the Quick 8, I miss tree a tad and spun the tires (of course it’s 94 degrees out)! So I made 6 passes, oil pressure good and haven’t touched it, I’ll take it for the first time out!
GTO George
  #164
Old 07-04-2020, 05:33 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
GTO George
I don't know how you do it in that heat. You must have a steel firewall and a -5 fire suit.
Congrats on the good runs.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #165
Old 07-05-2020, 09:16 AM
GTOGEORGE's Avatar
Jim
Yea steel firewall and floor........hence the 3,200 weight!
GTO George
  #166
Old 07-05-2020, 11:40 AM
GTOGEORGE's Avatar
I’m done racing this weekend, I tried to make a pass today but the track prep wouldn’t hold my engines power. I’m sure the 95 degree temps didn’t help but I’ve been in Kentucky in 101 temps and hooked. Anyways the car/engine is in one piece so I’m happy!
GTO George
  #167
Old 07-05-2020, 01:37 PM
.... Anyways the car/engine is in one piece so I’m happy!
GTO George
That's always a positive.
Jim
7.75 @ 178 pass:
  #168
Old 07-06-2020, 08:52 AM
GTOGEORGE's Avatar
Game plan for today......or tomorrow (depends how i feel) is unload GTO, put on hoist, remove diaper, drain oil & remove oil pan (to check bottom end), remove blower & retorque heads. Just regular PM stuff! LOL!
GTO George
  #169
Old 07-06-2020, 03:22 PM
GTOGEORGE's Avatar
Just took a compression test and drained oil then taking pan off and the engine is perfect NOTHING in oil or oil pan.......hell there’s not even water/condensation in the oil!!!!
That’s 7 passes in 95 degrees temps!
GTO George
  #170
Old 07-06-2020, 04:19 PM
Stan Weiss's Avatar
GTO George
George,
Do you cut your filter open?
Stan
Pontiac Pump Gas List
  #171
Old 07-06-2020, 05:14 PM
GTOGEORGE's Avatar
George,
Stan
Yes.
Normally if I don’t have anything in my pan there is nothing in filter.
GTO George
  #172
Old 07-08-2020, 12:27 PM
GTOGEORGE's Avatar
Youtube videos from Mid-Michigan.
First round WIN on Friday and 2nd qualifying pass for the Quick 8 on Saturday. I qualified no.5
https://youtu.be/ABH7mhycOiw?t=2
GTO George
  #173
Old 07-09-2020, 03:52 PM
GTOGEORGE's Avatar
Along with the above mentioned PM work to my engine I also retorqued the heads (120 center studs & 115 on the rest) and checked the lash on my valves. Oh I'm also getting new slick mine are toast!
GTO George
  #174
Old 07-09-2020, 04:59 PM
GTOGEORGE's Avatar
George,
Stan
Just got through cutting my filter apart, looked pretty damn good!
GTO George
  #175
Old 07-09-2020, 07:27 PM
....... Oh I'm also getting new slick mine are toast!
GTO George
How many passes do you average on a set of slicks, George?
Jim
7.75 @ 178 pass:
  #176
Old 07-09-2020, 07:35 PM
GTOGEORGE's Avatar
Jim
Thats a good question...........ive been trying to figure out when i bought the slicks, ill try to come up with a number later!
GTO George
  #177
Old 07-16-2020, 11:05 AM
GTOGEORGE's Avatar
Well I bought me a new pair of slicks, I looked at my old ones and decided they were dead.......dont know how many passes on them ill try to figure it out later. Got my slicks on and the car is loaded up on the trailer for my next race (July 24-26) at Milan (Detroit Dragway Reunion), its basically a 3 day race......Friday is a test and tune day with a Gamblers race mixed in and Saturday is the Official race, Sunday is Milans normal Dragrace day. Friday i plan on making a couple of passes back to back with some jet changes and plug reading so Sat & Sun I wont have to touch it! I hope its not a 95+ degree weekend again!
GTO George
  #178
Old 07-26-2020, 01:17 PM
GTOGEORGE's Avatar
I’m back from Milan and it wasn’t a great weekend. My 2nd Timed pass on Friday I broke a blower belt, guess I should have changed it a while ago it’s a poly chain Kevlar belt, i didn’t have a spare, I have never thrown a belt of broke one......I’m bad my fault even at 66 I’m stil learning! On a positive note it went 8.08 when I tossed the belt 7 sec into the run about 800-900 for from the starting line! Going to order 2 belts, live and learn.
GTO George
  #179
Old 07-26-2020, 06:39 PM
Stan Weiss's Avatar
GTO George
George,
Post up the time slip.
Stan
  #180
Old 07-26-2020, 10:11 PM
George,
Stan
Tough crowd.
Jim
7.75 @ 178 pass:
Closed Thread
