Old 02-26-2020, 10:05 AM
JUDGE3 JUDGE3 is offline
Default Gauge cluster numbered connector
Anyone have a pin out call out diagram for the numbered connector that plugs into the back of the instrument panel gauge cluster? what each number designates?
thank you, I would think its same 70-81
Old 02-26-2020, 08:41 PM
Brentco's Avatar
Brentco Brentco is offline
I happened to just be looking at the gauge cluster printed circuit diagrams. Here is one from the 1975 shop manual.
I think they changed a bit through the years though.
File Type: pdf 12 - Chassis Electrical - Printed Circuit.pdf (127.3 KB, 97 views)
Old 02-27-2020, 12:14 AM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Here is '74 with gauges...
ID:	533104   Click image for larger version
ID:	533105   Click image for larger version
So long, farewell.
Old 02-27-2020, 03:37 PM
Formulabruce's Avatar
They are different almost every year. Gauges with clock is different too.
Old 02-27-2020, 06:53 PM
Default what wires for alt warning, brake warning?
Here's pics of what I have...…..
I'm needing to know specifically which wires are "alt/battery warning light" and "brake warning light".
The car is a 1973 Firebird. no gauges just the warning lights.
I'm installing speedhut gauges (no volt gauge) and have 12mm led warning lights I still want to wire up and use for these.
little did I know, you all are telling me each years different. I found online practically every pin call out for other cars/makes but no 2nd gen firebirds! I have a build manual but it doesn't show a pin call out.
Old 02-27-2020, 09:40 PM
Brentco's Avatar
Yeah you need the shop manual for the pin out information, as far as I know it's not in the assembly manual. Hopefully someone can share a diagram for '73. Barring that, and assuming you still have the original gauge cluster, you can always hook up 12 volts to the cluster and touch each tab contact on the printed circuit with the positive wire. When the alt warning light and brake light activate, you know your pins.
Old 02-27-2020, 11:18 PM
Here, try this one. Red numbers correspond with the numbers on the connector.
Interesting. My diagram is incorrect. Let me modify it to be correct for your pinouts.
Corrected version...
So long, farewell.
Old 02-28-2020, 07:47 AM
Thank you very much held for ransom. more helpful than you know, wiring is my weak link. perfect!
