Old 04-12-2020, 04:48 PM
grd777 grd777 is offline
Default are all the trans am dashes the same
i thought that the latter year dashes had some minor differences .got a lead on a great dash out of a 75 and want to know if i could use it it my 72 car
Old 04-12-2020, 07:08 PM
'70-77 will interchange, but '70-72 have a finer grain. George, am in similar situation, have a very nice '74 dash, bought to use in my '72. It may go in the '77, as am planning on sending several cores to Al Knoch to remold.
Old 04-12-2020, 09:36 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
All years will interchange but won't be correct. As OPH noted, the '70-'77 are interchangeable for the radio, but the grain was different on the early dashes. Starting in '78, GM changed the radio so the opening in the dash for the radio changed with it.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 04-13-2020, 06:12 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
I have a dash thats been tucked away for so many years I am not sure what radio style opening it has, or if it has the grab handle. I sure hope it's the 78+ style as it will be going in one of my 78's some day. Hopefully I knew the difference when I bought it, but I don't recall of the top of my head.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 04-13-2020, 10:50 AM
TAKerry TAKerry is offline
Easy to figure out by measuring the radio, the grab handle was for the deluxe int. package.
Old 04-13-2020, 11:34 AM
thepontiacman's Avatar
There is also a part number on the backside of the dash. This may help some.
Old 04-13-2020, 02:17 PM
Grand73Am Grand73Am is offline
This picture for dash caps shows the difference between 70-77 and 78-81 dashes. The strip of dash between the radio hole and the ash tray hole is 3/8" thick for the early dash, and 3/4" thick for the later dash. So that's an easy way to tell.
DASH EARLY LATE DIFFERENCE - Copy by grand73am, on Flickr
Steve F.
Old 04-13-2020, 10:02 PM
looks like the ash tray area is different also
Old 04-14-2020, 06:26 AM
68ragtop's Avatar
Looks like the ash tray is bigger in 78? I had no idea at all.
Promotes a safer smoking experience.
89 Trans am GTA
Old 04-14-2020, 06:46 AM
68ragtop's Avatar
Pulled mine out of storage because curiosity got the best of me.....
I am thinking & hoping this is the 78+ style? No grab handle but has the mounts on the backside for it.
Also date in the mold of 1977. All these years & I never knew that was there. Right above the glove box opening.
ID:	537271   Click image for larger version
ID:	537272   Click image for larger version
89 Trans am GTA
Old 04-14-2020, 07:52 AM
Yes, it's a 78-81.
Steve F.
Old 04-16-2020, 12:03 AM
Aus78Formula Aus78Formula is offline
The radio opening, and moreso the facia bezel for the radio is much more tapered on 70-77. Those are dash overlays so good for comparison but openings and detail won't match original, such as the recess for the ashtray. The measurements may differ also as have to be larger in areas to cover stock unit. So be aware what you are measuring and if it has a cover on it.
Old 04-19-2020, 10:01 PM
would the grain from a 78 ash tray and glove box door work in a 72 looks very close
Old 04-19-2020, 10:08 PM
I think they are referring to the dash pad covering. The glovebox is plastic PP and the ashtray is stamped metal.
Old 04-19-2020, 10:18 PM
i think i need to restate my question. i have a dash pad from a 71 firebird ,will need to restore it , but i need to add the glove box door , ash tray and the lover steering panel . i have some for a 78 ,will the grain match
Old 04-19-2020, 10:20 PM
'probably' no different. They didn't match anyway!
Old 04-20-2020, 08:09 AM
Not to sound like THAT guy, but if you have all of the parts already cant you put them together to see if they match? For what you need to replace I doubt it will make that much of a diff anyway, what Aus said.
Old 04-20-2020, 08:40 AM
Whoa...look out!! Easy Tiger, you don't wanna be That guy!
Just kidding, you have one dash covering and 2 different interpretations of the same surface from different methods.
Old 04-20-2020, 09:30 AM
Old 04-20-2020, 10:36 AM
Originally Posted by TAKerry View Post
yes i did that . very hard to tell the difference . i just wanted to know if someone here had any in put on this
