Old 05-18-2020, 01:27 PM
My64GTO My64GTO is offline
Default Hood Hinges
My normal procedure after going for a ride is to pull into my garage, open my hood, disconnect the battery and leaving the hood open allowing the car to cool.
Yesterday, after pulling into the garage, I attempted to open the hood. For some reason it bound and I had a difficult time opening it. After a little force, it opened, but not before hearing a loud "pop" from the drivers side hinge as it opened.
So I guess, one of this years' immediate projects is replacing the hood hinges because I am afraid if I close the hood again, I won't be able to open it. And since it is a 1 year hood, I don't want to jeopardize bending it, or causing other damage if that happens.
I plan on buying the hood hinge kit from Ames., but I have never done this before. Is there a proper way of replacing them?
Thanks!
Old 05-21-2020, 08:15 PM
scott70's Avatar
scott70 scott70 is offline
contact willie@hoodhingerepair.com. Aftermarket can be hit or miss,,,have your originals rebuilt.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 05-22-2020, 12:23 AM
ZeGermanHam's Avatar
Or you could always take a swing at refurbishing them yourself:
https://youtu.be/G2N5gRJbDpo
1998 BMW 328is (track rat)
Old 05-22-2020, 09:32 PM
mrennie's Avatar
mrennie mrennie is offline
Do this...I did and was very satisfied. They come back in new condition and fit like OEM parts should.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 05-23-2020, 01:03 AM
OG68 OG68 is offline
A third Yea vote for Willie. Fantastic job on my 68 hinges
2007 Cadillac SRX
Old 05-26-2020, 10:17 AM
Thanks for the replies guys. I will give Willie a call.
C-
Old 05-26-2020, 10:29 AM
dataway's Avatar
dataway dataway is offline
I was watching that video and I was wondering how that technique would solve the problem of worn rivet shafts or pivot holes that were egged out. Re-staking the rivet would tighten up the side to side slop but doesn't seem like it would help alignment issues from egged holes or worn rivet shafts.
I've done a decent amount of solid riveting, but I've never restored a set of hinges so I can't be sure.
Old 05-26-2020, 06:29 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Default Hood Hinges
Roland Hall did mine and said he made the rivets, $25 to stamp the letters on, and mentioned something about one of the rivets being hollow? Said he could put a solid rivet in if I wanted, would last longer so went that route. Never heard of the hollow rivet or peeps just trying to stake them.
Old 05-26-2020, 10:28 PM
jmt455's Avatar
jmt455 jmt455 is offline
Rowland Hall did my hinges; they are superb!
Email or call him to talk about your project first.
rowlandhall@mindspring.com
Tel 818-845-3574
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1923 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1968 GTO, 428, THM400, 2.73 posi cruiser
1969 Chevrolet C10 Fleetside, 350, THM400
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
Old 05-30-2020, 11:35 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Another vote for Rolland Hall!
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
