discoloring of center of intake manifold
Does anyone know how to stop the paint from discoloring on the intake manifold. I'm talking about the center crossover port. I have a 1967 GTO and I am always repainting this location on my car. I think I heard of a way to block this cross over sometime back but have forgotten how.
Thank you Alan Mayhew |
Discoloring of Center of Intake Manifold
This is what I do to the exhaust crossover of the intake manifold, as well as the exhaust side of the cylinder heads where they burn the paint off and rust.
I spray a couple coats of high temperature aluminum (header) paint on these areas before the Pontiac Blue. Then spray the entire part with Pontiac Engine Blue (mine happens to be a 69). Then when I first fire engine I don't let it get too hot and then let it cool. (I know nearly impossible when breaking in a flat tappet cam but, I use hydraulic rollers.) Do this a couple of heat/cool cycles and has worked well for me. Probably 12-15,000 miles since last time and still looks good. |
Are you using a choke?
Blocking that runner will interfere with it's effectiveness....besides, the paint isn't usually the point of blocking that off, although it is a side benefit. I have been using the high temp silver paint trick as well. It improves the appearance of the hot spots quite a bit..
Greg Reid Palmetto, Georgia |
I've done the high temp silver paint trick with reasonable results, in my case it still eventually discolored to some extent but it took longer and wasn't as bad.
I normally block the driver's side of the port.
Choke still works, paint looks better. Carb runs cooler. Winner!
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
thank you
Just painted the exhaust ports on my heads with VHT flameproof (exhaust header paint). They make a silver and a blue so I dispensed from the cans into my airbrush (through a soda straw) until I had a reasonable match to the Pontiac Metallic Silver Blue .I sprayed a silver coat followed by the silver blue.
I will follow the curing process and see how the header paint holds up and get back to you.
Triple Black 1971 GTO |
I did several coats of Header paint before applying the engine paint, pics show one summer later, there's discoloration but atleast it's not rusty look, car averages 2000~2200 miles a year approx from May to November.
78 T/A 4SPEED, Original paint, match #’s, mine since ‘99. 77 t/a sold 85 Monte Carlo SS sold 83 Mustang GT sold Last edited by phil400; 07-05-2020 at 01:19 AM. Reason: Meant May-November, not May-April |
Thanks but I have heard of intake manifold gaskets with this center ports not cut into the gaskets so when you put on the gasket it blocks the exhaust from crossing over. Anyone heard of this???
All the performance intake sets come with inserts that block off the heat risers. Edelbrock includes both a full block off and a partial block off plate. The intake still gets hot enough to discolor the paint even if blocked off though.
Gasket material will burn thru ,
Some people have used stainless shim stock to close the ports off with the use of standard gaskets. I just modified an old P4B for my 67 GP removing the crossover RAIV/HO style. Car runs "much smoother without all that heat. In this cases I machined up some block off plates
Carburetor building & modification services Servicing the Pontiac community over 20 years |
I've also used the Fel-pro 1233
Felpro sets come with the block off plates even has a dimple in the middle to line it up.
thanks I ordered some from summit
