Old 04-17-2024, 11:20 AM
nh68gto's Avatar
nh68gto nh68gto is offline
Question 2004r tube
Will fill tube from th400 work on the 2004r ?
69 GTO. TY
Send it! It’s going home on a trailer.
Old 04-17-2024, 04:03 PM
67Lemons 67Lemons is offline
I can’t say for sure but are the dipsticks the same length? To be safe I’d definitely measure both dip sticks & tubes before making the swap, if one is missing then to be safe I’d just buy a new dipstick & tube for the 2004R if that’s what will be in the car after the swap, you don’t want to run your transmission low or even high on trans fluid because you're using the wrong dipstick.
Old 04-19-2024, 02:30 PM
SRR's Avatar
SRR SRR is offline
I don't think so because one uses an 0-ring and the other a bushing type seal.
― Calvin Coolidge
Old 04-19-2024, 04:08 PM
69 GTO. TY
No it won’t.
Not only is the 200-4R tube sealed differently than the TH400 tube, the tube itself is configured differently where it enters the transmission and it also must match the car’s firewall shape.
Even if the same car could have been optioned with 3 different types of automatic transmissions all 3 dipstick tube assemblies would be different.
Your best bet is a Lokar setup that’s flexible and can made to fit multiple applications. Unless someone chimes in with the correct factory tube that interchanges the Lokar tube is probably your best bet.
Sometimes a later model car with a similar firewall configuration that came with the 200-4R can be a potential donor. A 1980s Buick GN or Monte Carlo SS that used the 200-4R might have a dipstick tube assembly that works, just throwing that out there.
When I needed a dipstick tube to upgrade my ‘64 Le Mans from a 2-speed ST300 to a 3-speed TH350 I rolled the dice and purchased a ‘70 Le Mans TH350 dipstick tube assembly. It worked like a charm, clearly the relationship between the engine and transmission assembly to the firewall is pretty much identical on ‘64-‘72 A-body cars.
