Old 12-03-2021, 04:42 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Default Rear end width?
I found a 1967 Pontiac Tempest rear end at a swap meet today. It came out of a car that had been totaled. I know the car and the owner. The rear end was converted to a 3.55 posi-traction with the pre China Yukon gears. It still has the stock axles. It has also been converted to disc brakes.
I have a couple questions about it. First, I rough measured the width from the wheel mounting surfaces and got 60 3/4"s. Can someone tell me what the measurement would be on a drum brake set up? And, where can I find the codes stamped on the axle?
I would like to put this in my 67 GTO but I am very close on wheel clearance now with my stock rear end and the 17x8 Rally IIs from year one. I can't go any wider than what I have now. If the disc brake conversion widens the rear end would it help to revert to the drum brakes?
Old 12-04-2021, 03:56 AM
lust4speed's Avatar
Size for the standard mid-year 1966 and later GTO differential is as follows:
Axle flange to axle flange is 60 15/16 inches
Backing plate to backing plate is 55 1/2 inches
Spring perch centerline to centerline is 35 inches
Shock mount centerline to centerline is 49 1/4 inches.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 12-04-2021, 10:26 PM
fyrffytr1's Avatar
Thanks for the reply. I passed on this one today. When I rotated the gears by hand I felt a rough spot. It felt like the gears were binding up. Maybe damaged by the wreck.
Old 12-05-2021, 07:55 PM
shifty's Avatar
shifty shifty is offline
Default Rear Measurements
GREAT info.
