Old 12-06-2021, 01:30 AM
467blkbird's Avatar
467blkbird 467blkbird is offline
Default 1968 Firebird 468cc 4-Speed - Priced to Sell FAST! $16,000 OBO
I have run into multiple family emergencies at the same time and need cash asap, as much as it kills me I have to sell my bird, I wish the pictures were better but this was a last minute thing and the weather outside is ugly.
I will also be listing on ebay, but I have really enjoyed the PY family and wanted to post here first.
Please look closely at the pictures, the paint is driver quality and has some small chips as well as what looks like a carburetor fire burn spot on the hood. The interior is fully dynomat, new carpet, the console is for an automatic ( was an automatic car when I got it), front seats are aftermarket leather seats, only gauges that work are the water temp, oil pressure, tach, and shift light. Runs and drives great, sounds amazing.
I have the PHS, car was originally Verdoro Green 350 AT. Please see the specs below, I will answer questions as quickly as possible. I do have videos / additional pictures available.
Located in Fort Wayne, Indiana 46835
Price is $16,000 OBO Open to offers!
My loss your gain, I need to move this as quick as possible.
__________________________________________________ _______________________________
1974 Iron Block Pontiac 400 - Bored and Stroked 468cc
Balanced and Blueprinted by Kauffman Racing Equipment
Ohio Crank Forged
Keith Black Pistons 4.185 Bore
Eagle Rods
Zero Decked Block
KP 400 4 Bolt Main Caps
Crower Cam 60919
Comp Cams 1451-16 Magnum 1.5 Roller Tip Rockers
Professional Products SFI Damper
Billet Timing Chain
KRE Aluminum 85cc Heads
ARP Head Bolts
MSD Pro-Billet Ready-To-Run Distributor
MSD Blaster 2 Coil
RobbMc 550HP Fuel Pump
Cliff Ruggles built Quadrajet (17059201)
Hedman Headers
3” Dual Exhaust
Muncie M-21 Close-Ratio 4-SPD (‘68 GTO Purchased from Jim Mino)
Hurst Competition Plus 4-Speed Shifter
Lakewood SFI Blowproof Bellhousing
McLeod Super Street Pro Clutch Kit
PRW SFI Billet Steel Flywheel
Southwest Speed Hydraulic Throw-out Bearing
Moser Engineering Custom Built GM 12-Bolt
Eaton Detroit Truetrac Differential
US Gear- 3.73 Gear Set
Moser 33 SP Axles
Tubes Welded to Housing, Boxed-in Perches
Wilwood Dynalite Front Disk Brakes
1” Drop Spindles
Moog 1” Drop Coils
BMR Fabrication Heavy Duty Boxed Subframe Connectors
Calvert CalTracs Traction Bars
Hotchkis Leaf Springs
Rear Drum Brakes
ID:	579180   Click image for larger version
ID:	579181   Click image for larger version
ID:	579182   Click image for larger version
ID:	579183   Click image for larger version
Old 12-06-2021, 09:22 AM
467blkbird's Avatar
Default More Pictures
More pictures
ID:	579187   Click image for larger version
ID:	579188   Click image for larger version
ID:	579189   Click image for larger version
ID:	579190   Click image for larger version
Old 12-06-2021, 09:35 AM
HoneyHush HoneyHush is offline
Can you send me your phone number as soon as possible? 859-360-8421. Thanks. Or call me
Old 12-06-2021, 09:37 AM
Pm sent.
Old 12-06-2021, 10:23 AM
Are you in a position where you could deliver the car for some more 'bens'?
Google map says your 571 miles away. That's Fort Wayne to LaFayette, GA.
Clay
Old 12-06-2021, 11:11 AM
467blkbird's Avatar
Default Sale Pending- I will update today.
Old 12-06-2021, 11:20 AM
Ok. I did all I could
Old 12-06-2021, 10:36 PM
467blkbird's Avatar
Default Sold- Thanks PY!
Sold- Thanks PY!
