Old 01-20-2021, 03:49 PM
hfpjr76 hfpjr76 is offline
Default Moving brake to firewall
55 chieftain going to move pedal from frame to firewall anyone used a certain year or make pedal bracket that made this conversion easier? I’ve seen a few said tri-five chevys are the way to go?
Old 01-20-2021, 07:15 PM
694.1 694.1 is offline
Pretty sure that you need to eliminate the defroster when you move the Master cyl.
I looked at a car a number of years ago that was done very poorly and the seller endured a lot of disgusted tire kickers...including me!
Some talent-less clod really messed up a nice car.
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 01-20-2021, 08:14 PM
That’s not a issue the defrost & heater are shot, im going vintage air for that stuff anyway. I’m just looking for what might fit the best and look nice. I’m no butcher and my car will never be for sale lol I’m just seeing what’s out there & been done to maybe save sometime ty
Old 01-20-2021, 11:23 PM
On a customer's car we made a bracket for a Wilwood remote dual master - worked fine. He nor us wished o butcher the defroster.
Old 01-21-2021, 07:13 AM
I’m going vintage for heat & ac so the defrost I’m not too worried about since it doesn’t work anyway.
I have your brackets on my 63 bel air great product!!!!
Old 01-21-2021, 09:51 AM
You guys still making that bracket?
Old 01-21-2021, 04:12 PM
Thanks - We do, they are here:
http://scarebird.com/index.php?route...product_id=123
I was not impressed with the all-in-one packing of the Vintage Air unit - I would examine other options before selecting.
Old 01-21-2021, 06:14 PM
Bill Eveland's Avatar
I have mine on the firewall. I welded in a 1/8" to reinforce the area. I use a 55 Chevy pedal assembly and a mopar mc. I couldn't use the full assembly, the speedometer was in the way so made a bracket to support it under the dash.
As high as I mounted it, the factory pedal wasn't long enough to where it should have been. So found one from a truck and had a nice offset to go around steering column and bolted and welded to factory 55 pedal arm. Which actually gave me a nice 6:1 ratio for manual 4wl disc brakes. Than used an adjustable Wilwood prop valve.
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 01-21-2021, 10:00 PM
Ok thank you good to know on the vintage air, do you recommend anyone??
Old 01-21-2021, 10:10 PM
I was planning on reinforcing the firewall, I’ve seen others say the 55 pedal so I going to grab one up. I’m doing a booster I want power brakes this is a cruiser so no crazy cam or engine work done. But then I’m also thinking of leaving it where it is since scaredbird has that bracket decision decision.....
Old 06-16-2021, 03:40 PM
Sleepy33's Avatar
Sleepy33 Sleepy33 is offline
My pedal has been moved to the firewall on my 56. The pedal had a part #. From a mid to late 90’s chevy truck. Apears the booster,master cylinder and engine came from that source.
Brian
Old 06-18-2021, 06:41 PM
Sleepy33's Avatar
Took a couple pictures of my pedal assy today
Brian
ID:	568435   Click image for larger version
The Following User Says Thank You to Sleepy33 For This Useful Post:
Old 03-10-2022, 09:31 AM
Brian
Looks great what year car? Chevy or Pontiac?
Old 03-10-2022, 12:58 PM
Sleepy33's Avatar
1956 Pontiac 2dr wagon
Brian
Old 03-10-2022, 12:59 PM
Brian
Sweet ride!!!
Old 03-10-2022, 09:12 PM
Speedway Motors (and probably others ) sells a whole kit for mounting the master on the firewall. Comes with bracket and pedal.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 03-10-2022, 10:43 PM
I spoke with them and ended up up getting a 55 Chevy pedal needs a little fab but looks close.
