Old 11-19-2021, 02:52 PM
AdamRR AdamRR is offline
Default GTO '65 transmission parts
Hello Everyone,
I bought a beautiful GTO '65 at auction, but someone replaced the clutch kit and the flywheel. Now the release bearing is too far from the clutch and
the flywheel does't fit the starter .
For sure, I want to order a new kit (Flywheel, Clutch, Clutch Fork and Ball Stud)
I have parts decoded (I think so):
- transmission: P8H20 = june 20 '68, muncie m20
- engine block: S1/k10 = 61' 389 cu
What do you think, what I should buy?
ID:	578093   Click image for larger version
ID:	578094   Click image for larger version
Name:	engine code2.jpg
ID:	578095   Click image for larger version
ID:	578096   Click image for larger version
Old 11-19-2021, 03:54 PM
Sirrotica's Avatar
If it's a 61 block, there is no mounting boss on the block for a starter. The 61 block would also require a 61-63 bellhousing, (bellhousing mount starter) to be used in a 65 GTO chassis. The 64 and later bellhousing is made from aluminum, while the 61-63 bellhousing is cast iron.
Are these parts that you have?
It looks like you're trying to use a mini starter also?
The ring gear does not appear to be on the flywheel all the way, but it's difficult to be sure from that picture.
To add to the difficulties GM also used 3 different height throw out bearings through the years, depending upon what clutch setup you have.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-19-2021, 04:42 PM
Yes, I have mounting boss on the block for a starter.
https://butlerperformance.com/i-2445...i-p010004.html
and this is my starter
https://butlerperformance.com/i-2445...r-imi-123.html
This confirms the codes on the engine block
That's right, the starter is half on the flywheel. Additionally, the flywheel has flange.
The throw out bearing = 32 cm high (1 1/4 in).
ID:	578114   Click image for larger version
Old 11-19-2021, 04:54 PM
Bill Hanlon's Avatar
The fine print on that Butler part says "for automatic transmission only"
Old 11-19-2021, 05:18 PM
Sorry wrong link, I don't have a picture of the adapter but it fits the manual transmission. The adapter has a flat surface.
I think you can see it in the pictures
ID:	578117   Click image for larger version
Old 11-19-2021, 06:40 PM
Sirrotica's Avatar
FWIW, Bendtsen and Wilcap, the 2 companies that make these type of adapters both list for automatic transmissions. Although I'm fairly certain that the OEM starter fits both applications, there must be some reason they qualify it only for automatic transmissions............
Either the mini starter has too short of a stroke to put the Bendix gear fully into the ring gear, or the flywheel is made incorrectly and the ring gear is in the wrong place, (wrong dimension), or the adapter doesn't have the correct dimensions from the rear of the block to the flywheel surface.
These are about the only things I can come up with for the picture showing the Bendix roughly 50% engaged into the ring gear. Possibly someone else has a better explanation than I do.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-20-2021, 09:50 AM
69hardtop 69hardtop is offline
I’m probably wrong, but that flywheel looks incorrect. I think the starter ring gear is in the incorrect position because of that
Old 11-20-2021, 08:03 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
65 and newer ring gears were in a different position, so if its a newer flywheel that may be your problem.
Old 12-05-2021, 01:35 PM
61vette 61vette is offline
You have the wrong flywheel installed. Here is a couple if pictures of an original flywheel from one of my 1965 389 engines. I just finshed having it turned and a new starter ring installed. I am willing to sell it if you are interested. Click image for larger version
Old 12-05-2021, 03:30 PM
The 65-up flywheels will also work with 64 A-Body engines (326 and 389) WITH the Block Mounted starters.
