Looking at an engine for sale locally.
My son and I drove a couple hours to see a gentleman that has a Pontiac 400 for sale. It's installed in a '69 GTO, but It's not the original motor to the car. It's a built up motor that he put in place while he slowly re-did the original engine. That original engine is now ready to take it's rightful place in the GTO. The engine that's for sale looks good, sounds good, etc. The vendor seems like a good guy.
The only thing that niggles me is that the parts are more high performance oriented, and I'm wondering if it makes sense to put it in our creampuff. Our car requires a good vacuum to run the A/C vac control lines, the cruise control, and power disc brakes. I don't have actual part numbers for the motor, but here are the general specs: Built up block with Eagle rotating assembly. Edelbrock RPM round port aluminum heads with roller valve train. The camshaft is a roller version of whatever original Pontiac cam would suit this combo. Edelbrock RPM intake, Carb TBD, but not a Quadrajet. But a good one. MSD HEI ignition. It's a relatively new engine with not many miles. We heard this thing running and it sounds sweet when driving, but the idle is a little lopey. I was on the Edelbrock website and noted that the RPM products perform best starting at 1500 RPM. So I would have preferred a motor with the Performer D-port heads and Performer intake. But this is a good deal. About the same as 2900.00 for you guys. Just to get Edelbrock heads here, delivered, would be that alone, plus sales tax 13%. I also noted that Edelbrock doesn't have any anyways. So can I make this work in my car or not? Seriously, I'll probably just buy this motor anyway, but it would be nice to drop it in the LeMans without farrting around with the car too much. |
idle vacuum and rpm?
It will need different headers or exhaust manifolds, unless his come with the engine. Not sure if headers interchange from 67 to 69.
Sounds like a good motor and you can sell off the lack of bottom end torque making Round port heads to fund getting KRE D ports that are more like what it sounds like your driving needs require.
Sounds like a good deal based on parts. The seller doesn't know specs on cam? The description you provided doesn't offer enough info to indicate if too radical for street driving. Is it a stroker?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Sounds like a deal for the money, run it
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I forgot to mention that it does come with Hooker headers. I'd put the round port exhaust manifolds on it, if they fit the '67.
The seller didn't have the exact specs for the cam, but he mentioned that it was a "Ram air 4" type cam. He didn't build the engine himself, he had a shop do it. I'm thinking that with this engine as it sits, it would be challenging to tame it down. And we were thinking, exactly as mentioned, that we could sell the top end and use that to get some KRE's or Performer heads if neccessary. But just getting a built up short block around here could cost 5g's or more, so either way it seems like a win. I'll say one thing, though. The sound of him driving away was intoxicating. That engine is tight. He did have power brakes in the '69 GTO, so that gave me some hope for the engine making decent vacuum. Last edited by 66sprint6; 06-28-2021 at 09:42 AM. |
for that price its a steal... E-heads would cost almost that much alone. buy it before the guy realizes what its worth. it should run fine on the street & if needed you can always change the cam with not much work.
The Following User Says Thank You to grivera For This Useful Post: | ||
Aftermarket 400 cranks were/are not all that common.
Stroke could be checked through a spark plug hole.... The cam could be tamed down with Rhoads lifters. An add on vacuum reservoir can help, if needed. Read somewhere here is last day or so, that Canada is considering opening up the border, in a month or so.....was going to post on one of your threads about this, thinking again about Len Williams....... I'd be a buyer at that price!!!
I'll have to ask if it's a stroker. We didn't get that far into the details. The seller was an older gentleman who has 5 cars and a bunch of Harley's. It seems that he doesnt do much work on them himself. He's paring down on the cars and parts, though. That's why he's selling this engine rather than just have it on a stand.
Remember I have some friends (here in Oklahoma) that own a small trucking company. If a Len Williams deal was able to be struck, contact me. THey could get the engine to the border. I'd ask for favor for you..... I'd like to think the the owner of this potential engine for you could give you the name of shop that performed the work, so you could get an idea of the parts used. But if that might involve the passage of too much time, I'd buy the engine, just to make sure someone else buys it...
Stan
Buy it.
Leave it alone, clearly it’s a nice running performance engine. Buy a good torque converter that complements the engine. Perhaps for a bit extra the seller can set you up with the one he’s using now. Enjoy.
The Following 3 Users Say Thank You to b-man For This Useful Post: | ||
No point in tearing down a good engine, if it's not you, find one that is. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
ight check it is not a 557 casting block to know how hard you can lean on it. But sounds like a deal to me!
Not sure how you can go wrong.
1970 GTO (Granada Gold) - 400 / TH400 |
Thanks, guys. I called him and e-transfered a deposit. I figure the next guy that doesn't mind driving a couple hours to look at a motor will likely snatch it. We have confidence in the purchase, pretty much because we saw and heard the motor in the car running.
We'll get it in a week or two. I told the guy no rush. Then the fun begins. I'll update as this evolves. |
The Following 2 Users Say Thank You to 66sprint6 For This Useful Post: | ||
"but he mentioned that it was a "Ram air 4" type cam." - sort of an 041 ? Lotta cam for a 400. If an automatic might go a little loose on the torque converter. Probably a nice match for a built 200R4.
