Old 07-03-2020, 04:58 PM
dataway's Avatar
dataway dataway is offline
Default Weld through paint
Anyone know of any good weld through paints or coatings? I'm doing a floor pan and I've got an area where the metal needs to be clean to be welded, but once welded I would not be able to get to the area to paint it. Only reason for the paint would be to prevent rust. I could, if necessary, flood the area with a rust inhibitor if no such weld through coating exists .... but seems like I've heard of them.
Old 07-03-2020, 05:17 PM
Yeah, you can get it at any auto body supply house. It ain't cheap. The last can I bought, I almost fell out in the floor when he rang it up.
3M brand '05917 Weld Thru II'... It was damn near $30 for a 20oz rattle can.
Here, this is easier.... https://www.autobodytoolmart.com/pro...hoCZcEQAvD_BwE
The Following 3 Users Say Thank You to Greg Reid For This Useful Post:
Old 07-03-2020, 08:17 PM
tjs72lemans tjs72lemans is offline
That's about all I've heard of and used is weld thru primer by 3M.
Old 07-03-2020, 11:40 PM
PontiacJim1959 PontiacJim1959 is offline
This may sound funny, but I use the hi-heat barbecue black, ie the high heat paint used for your outdoor grille. Paint is going to burn, no way around it, but the store bought spray bomb worked pretty good for me and burned off minimally, then just clean up the burned paint and re-spray. Just spray, let it dry a day or 2, then weld.
Just a consideration.
Old 07-04-2020, 04:28 AM
dataway's Avatar
Thanks Greg ... that sounds like the ticket.
Old 07-04-2020, 07:40 AM
rwfisher's Avatar
rwfisher rwfisher is offline
I've used SEM copper weld and it is a little cheaper than 3m, covers well and works well. Also comes as brush on if you prefer that
Old 07-04-2020, 08:14 AM
dhutton dhutton is offline
Use it sparingly, a very light coat or your weld will be garbage.
Don
Old 07-04-2020, 01:44 PM
Be aware, it's not actually a primer. You have to remove it from any surface that will get paint. For that matter, the instructions say to remove it from any spot where you've punched a hole to simulate a spot weld. Plug welds actually...remove it from the middle of the hole.
By the way, after looking at the can, it's not 20oz.....It's only 12.5oz for damn near $30.
Old 07-05-2020, 07:48 AM
dataway's Avatar
I actually ended up getting this stuff. Solely based on reviews.
Seymour 20-1675 PBE Professional Primer, Self Etching/Weld Through Gray
Old 07-05-2020, 12:15 PM
Like most people that use weld thru primer, it's protection in an area that can't be prepped once welded. This was this poster's issue. So, no reason to worry about paint.
Old 07-05-2020, 03:24 PM
Well yeah, that's true and that's all it's really for..but the word 'primer' ...which appears nowhere on the can by the way....might lead some to think it's ok to leave overspray on an outer surface.
Old 07-05-2020, 03:42 PM
First Bird's Avatar
First Bird First Bird is offline
I've used Upol Weld Thru primer. It worked well
- Tom
Old 07-05-2020, 07:32 PM
dataway's Avatar
I was looking at the UPol stuff, its very highly rated by the customers.
Old 07-09-2020, 06:38 AM
bkmont's Avatar
bkmont bkmont is offline
Same here.
Old 07-15-2020, 03:05 PM
chiphead's Avatar
chiphead chiphead is offline
Upol copper weld thru works great and no zinc fumes
Old 07-15-2020, 04:37 PM
dataway's Avatar
Since I haven't started the project yet ... I ordered some of the Upol also.
Old 07-15-2020, 10:49 PM
MUSLCAH MUSLCAH is offline
Yup...same here....then aftah welding I make some access holes and blast in the 3M cavity wax ..with the long tubes and 360 degree spray heads...works slicker than snot on a door knob.
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 07-20-2020, 06:33 PM
Formulabruce's Avatar
Some info, "Weld -Thru" means "Induction Welded" , Not Mig welding. These primers don't burn up, they melt around the spot weld to give it corrosion protection.
I have used when plug welding, but that is not the true purpose of this primer. It was never designed to Burn up.
/\/\ Cavity wax is good stuff.
Old 07-21-2020, 12:45 AM
dataway's Avatar
My major concern is on the back side of a MIG plug weld. So it should be ideal for me, or at least better than nothing.
Old 07-21-2020, 04:16 AM
dataway's Avatar
Just read the instructions on the U-Pol "Weld #2" copper primer ... says it's suitable for resistance spot, MIG and TIG. Find it hard to believe you could TIG weld through any coating at all, it's certainly not very tolerant to any kind of contamination.
