Old 05-29-2020, 01:50 PM
ta man ta man is offline
Looks great ...How much weight was loss on the front end?
  #102
Old 05-29-2020, 03:06 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Thank you, so far i have weighed the following
radiator support = 38lbs
bumper brackets = 10lbs
crash brackets in the bumper = 26lbs
The new moly assembly is about 10lbs
I haven't had a chance to weigh the bumper and the valance yet, neither are very much once the crash stuff is out of the bumper. If i had to guess i'd say close to 20 lb difference from steel to glass for both. Probably 3 or 4 lbs difference between the original metal Luxury LeMans grilles and the standard plastic 72 grilles
Up next will be the radiator mount once the engine is set in, control arms, spindles, and rack.
Waiting on a few motor parts to show up and then the 400 will be ready to throw back together. I'm excited to see how it scales out, thinking I should be able to get to 100# or over once the suspension side of it is done.
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
  #103
Old 05-29-2020, 03:14 PM
Looks good Adam!
thanks Paul
1972 Pontiac LeMans
Thanks to
The Following User Says Thank You to adam woodmancy For This Useful Post:
  #104
Old 05-29-2020, 07:34 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Nice Adam!
I am about to start on my ‘72 GTO. Waiting on my ‘glass valence, fenders and doors. Already have the hood and bumper.
What size tubing did you use?
  #105
Old 05-30-2020, 01:00 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Jack Gifford View Post
With plans to get to the first 2020 LTA event on the 1.5 mile Loring ME track, just minor changes to the lakester-
> Halotron-1 agent replacing foam in driver's fire system
> Some body work around the hole I made for the blower
> Try to find someone to mold a "smooth" Lexan body piece over the blower
> Add a solenoid activated secondary fuel bypass, for consistent lean warm-up
> Source a blower pulley to allow driving the blower a little faster
> Perhaps outfit the '59 GMC as tow/push/support vehicle
> Most important- stitch my name in place of prior owner's name on the used -15 firesuit I bought
As I should have known, the list about doubled (Halotron-1 also in engine compartment, added GPS speedometer, A/F ratio gauge, etc.). Nevertheless most items checked off. And the bed liner actually fits in the GMC!
LTA entry done... just crossing fingers that the event occurs.
  #106
Old 05-30-2020, 09:04 PM
Originally Posted by GTO Dan View Post
Nice Adam!
Thanks Dan, some 7/8 on the main tree and a mixture of 3/8, 5/8 and 3/4. We did a lot of it slip tube style
1972 Pontiac LeMans
Thanks to
  #107
Old 05-30-2020, 11:41 PM
GTO Dan's Avatar
Looks great.
Old 06-08-2020, 01:49 PM
Had a chance to weigh a few more parts.
Stock LeMans chrome bumper - bumper only, no crash plates = 20.35 lbs
stock front valance w/o lenses = 8.35lbs
glasstek fiberglass bumper = 4.1 lbs
glasstek fiberglass valance w/ lenses = 4.5 lbs
glass bumper and valance saves right at 20lbs.
total weight savings so far with the bumper, valance, and tubular front support/mount is right at 83-85 lbs There will be a couple pounds added on when we do the radiator mount, so probably closer to 80 lbs in the real world.
1972 Pontiac LeMans
Thanks to
  #109
Old 06-09-2020, 02:28 AM
Bummer... July event cancelled, so a long wait for the Loring Harvest event in October.
  #110
Old 06-09-2020, 09:33 AM
fairwayhit fairwayhit is online now
Hey Adam. Looks good.
How was that glasstek front bumper to work with? It looks like it fits closer to the body than the chrome one. Is it the same dimensions or did you trim it?
I’m curious about how much work you have into that to make it fit so nicely.
  #111
Old 06-09-2020, 12:56 PM
Good question, in those pictures, there was almost zero work in the bumper. All i had to do to pull it in tight was to slightly radius the back or the center part where it meets the header panel.
That being said, I fit that with the original luxury LeMans grilles
I removed those and installed the plastic standard LeMans grilles and the trim is orientated differently and the bumper was blocking the bottom chrome trim completely on the plastic grilles.. I had to cut all the mounting tubes, microscope and extend them to lower the grille enough to make the chrome on the bottom of the plastic grilles show. When i did that, it created a monster gap in the center at the header panel. I had to cut the bumper and section it to close the gap ( still working on it ). I was able to keep the two side fasteners in the original place but had to extend the front three about 3/4"-5/8"
1972 Pontiac LeMans
Thanks to
  #112
Old 06-09-2020, 02:19 PM
Waiting on a few more motor parts and i'll get this pig together. Changed from the solid cam to a smaller duration, slightly bigger lift hyd roller. Stock 400 bottom end with .340@.600 eheads from Mike Leech. Not an optimal setup for performance, but for the bracket/index racing i do it works well because it mph's well for the e.t.s it runs.
1972 Pontiac LeMans
Thanks to
  #113
Old 06-10-2020, 09:37 AM
FYI
metal Luxury LeMans grilles = 5lbs each
plastic LeMans grilles = 2.15 ea
1972 Pontiac LeMans
Thanks to
  #114
Old 11-17-2020, 04:07 PM
It's been slow going on my end, but I have the rear end done and back in the car. We added the TRZ LCA brackets, cut down the uppers to accept the TZR spherical uppers, the lca support tube and a a couple little things like the tow loop and a fill bung. Adam at PRS freshened up my shocks, and I had Fuelab go through my pump and regualtor just to be safe. Next step will be welding in the ARB in the spring.
1972 Pontiac LeMans
Thanks to
  #115
Old 11-18-2020, 02:38 AM
Wow... time flies by...
It's time to talk about next winter's projects.
  #116
Old 01-07-2021, 03:53 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
If anyone is looking or thinking about upgrading their trailer over the winter.
My 32ft Vintage will be For Sale shortly.
Once I have everything moved over to my new trailer I’ll post with pics in the for performance parts sale section
White 2013 Vintage Outlaw
-32 foot
-triple 5200 lb axles
-electric brakes on all axles
-12volt electric tongue jack
-24” Tread plate stone guard
-48” side door
-6ft beavertail
-White L-shape front cabinets
-White right side Fender well cabinets
-MAC Tools,tool box
-5k pound winch with 12v battery in battery box
-1 piece aluminum roof
-13.5 BTU A/C unit
-rear roof vent with roof vent cover
-Sony CD/DVD/FM Stereo
-vinyl floors (Black Marble)
-New Maxxis E Load Range tires in February 2020
-6 lug Aluminum Wheels
-36X30 vented generator door
-24 foot shoreline cord 30amp
-2 LED flood lights on right side of trailer
-6 110v 4ft florescent lights inside converted over to LED bulbs
-12v LED loading lights in rear
-3 12v LED loading lights over head on ceiling
-LED rear tail/turn signal lights
$15,000
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
  #117
Old 01-07-2021, 10:22 AM
Fresh 462 for my street strip car. Adding a plate system. Hope to go 9.30s on a 275
  #118
Old 01-07-2021, 11:07 AM
Scott Stoneburg's Avatar
Nice! How big of a system you using? Whats it run on motor?
  #119
Old 01-07-2021, 01:05 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I will be putting off what I said I was going to do last winter to next winter.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
  #120
Old 01-07-2021, 05:38 PM
The car will run 10.00 on hp. I set it up for max 250 shot. Running a big shot plate.
