Old 05-27-2020, 10:08 AM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default 69GTO
Hi guys,trying to figure out what engine is in my new project.I'm going to try and send a pic of what #'s I have found so far.Thank you,Tim.
Couldn't figure out how to send pics #s 114618 ys on front of block and 1146 by dist.
Old 05-27-2020, 11:17 AM
Stuart's Avatar
Stuart Stuart is offline
YS was a valid engine code in 1969 for a 350hp 400ci engine with an automatic transmission. You can find more information on what the numbers mean on the Wallace Racing website: http://www.wallaceracing.com/enginesearch4.htm
Old 05-27-2020, 08:06 PM
I 14 6 would indicate an early production 67 model engine.
But they didn't use I - in 1967
So maybe the 6 - is an 8 ?
Making it a 69 model engine.
Which heads are on it
What are their date codes
Date on the intake by thermostat
What is the VIN stamped alongside timing cover ?
Wallace site has some webpages about how/where to locate the numbers and codes on engines, and how to decipher them.
Check it all out , and good luck
Old 05-27-2020, 08:53 PM
How many freeze plugs on one side of block?
Also find the block casting code on it. (on back of block area)
Old 06-13-2020, 10:13 AM
Default 69GTO
Hi guys,thanks for all the responses.I think I need to dive in there and get a better look.
Tim
Old 06-13-2020, 12:17 PM
android 211 android 211 is offline
The 69 auto standard engine had a 1111946 distributor. If yours is still on it that would be amazing as over the years people tended to replace and discard distributors when they wore out.
Old 06-13-2020, 03:31 PM
1969 Ram Air 1969 Ram Air is offline
Look for the partial VIN stamp on the front of the block, passenger side.
Name:	Pontiac Engine VIN.jpg
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
