Old 06-28-2020, 10:56 PM
Default Ever seen this
saw this on Instagram, not sure what to think..
Old 06-29-2020, 02:30 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Never even heard of it. Looks to me like a home-brewed affair.
Old 06-29-2020, 05:53 AM
Pretty useless if you want my 2 cents worth, not to mention dam heavy with 5 Carbs on it!
The tuned runner effect of having a Carb on basically at the end of each Intake runner in the head would make for a peak power tuned lenght of 8000 rpm or more!
Old 06-29-2020, 07:10 AM
Brian Baker's Avatar
1950's tech thinking. Run on the center carb until WOT and open the outboard carbs up. Not ingenious but kind of clever in placing the carbs in such a manner like you would with direct port injection...from a 1950's tech thinking process. No different in operation than a Tri-Power.
Old 06-29-2020, 08:48 AM
It's cool to look at. That's about it
Old 06-29-2020, 09:26 AM
sdbob sdbob is offline
Never. Never even seen an ad,J.C. Whitney etc. Trying to look closely at picture. Plenum for extra carbs?
Old 06-29-2020, 11:12 AM
Sirrotica's Avatar
No one has ever seen one of those most likely because it's a one of one.
BTW, it looks as though from the poor picture that it's a 65 and up, 2 bbl manifold with the other 4 added to it.
I don't have a picture of another home brewed manifold I saw at a Pontiac show in Columbus. They took a 66 tripower manifold and cobbled 3 AFBs to the top of it. The guy was pretty proud of it, it did run and drive. He told me he, and his son modified the intake.
When the show was over he was leaving and got out on the main road in front of the dealership where the event was held, punched it and the engine backfired, stumbled, sounded like crap, and he let out of it and continued driving. It was less than impressive, car I think, was a 66 GTO.
Not to be outdone, there is two videos on Youtube with an olds 442 with 4 Quadrajets on it, it also runs like crap.
Links to quadrajet madness: https://www.youtube.com/watch?v=Hy8rufA6Pyw
https://www.youtube.com/watch?v=Qa00UNBah18
At a minimum, 2600 CFM, could be as much as 3200 CFM, yep that ought to work really well. If bigger is better, than too much, should be perfect, but it wasn't........ Notice the revision in the first video coming out of the carbs on the road test.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-29-2020, 12:35 PM
GTO's Avatar
GTO GTO is offline
Innovation. Back in the day.
ID:	543733   Click image for larger version
Runner Up Q16 Norwalk 2013!
Old 07-04-2020, 01:33 PM
455firebird1969's Avatar
There was a guy running two Q-jets on a Cadillac 500 at Sears Point years ago...I thought it was cool.
If you consider the most common engine at the time was the SBC, he was thinking outside the box.
Old 07-04-2020, 04:23 PM
mgarblik mgarblik is offline
When 4 carburetors just won't do, try 5! Tri-power? Who needs a stinking Tri-power? My car has Cinco-Power! Fuzzy Dice, not included.
Old 07-04-2020, 05:03 PM
Stan Weiss's Avatar
If you were around back in the early days you have seen 6 and 8 carb manifolds.
Stan
Maybe this was the source for the 5 carb idea
Pontiac Pump Gas List
Old 07-04-2020, 05:30 PM
LATECH's Avatar
LATECH LATECH is offline
Wow .Incredible stuff right there
Old 07-04-2020, 05:35 PM
I have a 4 carb setup for a Pontiac that I bought from a PY member that mounts 4 Rochester 2GC Carbs and uses rubber tubing between the plenums.
For sure Old School Carb (cfm increase) type manifold.
The Man-a-fre 4 carb intake was one of the best ones in the day.
http://www.superchevy.com/features/1...-your-corvette
I have seen several 6 carb intakes over the years.
Old 07-04-2020, 05:48 PM
Stan Weiss's Avatar
If you are asking yourself why did they need so many carbs. Well it was different world back then.
How many CFM is a Stromberg 97?
While Stromberg produced carburetors for a variety of manufacturers, the two-barrels most hot rodders are familiar with first appeared on 85hp Ford Flatheads in '34 with the model 40; the model 48 was introduced in '35 (the preceding were both rated at 170 cfm); and from '36 to early '38, 97s were installed (155 cfm)
Stan
Old 07-04-2020, 05:52 PM
Was all about the # of needle/seats huh.
Old 07-04-2020, 06:31 PM
PontiacJim1959 PontiacJim1959 is offline
A little more info found here.
https://www.macsmotorcitygarage.com/...etors-why-not/
Old 07-04-2020, 06:57 PM
Even with You being an old guy, Jack, you can't possibly know everything about the old stuff.
Thanks PontiacJim1959 for the information.
I will have to spend some time on Mac's website, a local guy in Michigan.
Old 07-05-2020, 12:47 AM
... Looks to me like a home-brewed affair...
Quoting from PontiacJim's Motor City Garage reference:
"...apparently built up from a production Pontiac V8 intake manifold..."
I don't recall saying that I "know everything about the old stuff".
Old 07-05-2020, 07:01 AM
Jeff Hamlin's Avatar
Clearly a More the Better way of thinking.
Don't know if you don't try
Old 07-05-2020, 07:12 AM
The website shows a modified Pontiac Intake but a similar olds intake (picture #3) obviously is a cast up piece. All I see if that when he put the article together he could not find a photo of a 5-1 cast intake for the Pontiac at the time.
Seems we had a similar discussion about Mickey Thompsons "intake and exhaust ports on the same side" heads were some insisted the heads were modded production heads.
Have a great day Jack.
