Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Closed Thread |
#141
So still waiting on parts.......I will never buy anything fro m QuickFuel again! My wife talked to them on Wednesday and the part still isn’t shipped out yet!
GTO George |
#142
While I’m waiting for carb parts I’ve been working on my wife’s TA engine.......I’ll be dropping it in shortly!
Oh yea.....it fits under the hood!! GTO George |
#143
World's longest blower drive snout?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#144
It’s around 9” long, it’s basically the same that I had on my original 1974 GTO and then I my car that I race now! The B & M Blower (Now owned by Holley) made a great street blower! I never broke it, tame for around 10 years spinning it as high as 13,000 rpm. In the car I have now it ran as quick as 9.45 in the 1/4 mile on 3-4 lbs of boost. Best street blower ever they were sure made to last, I beat the crap out of it!
GTO George |
#145
Finally got my engine started........!!!!! Started right up BUT having problems with getting water to flow when pump comes on, normal it’s a pain BUT this time it’s a lot worse. Today I’m going to adjust the floats and fuel pressure and then hopefully get the water flowing.
GTO George |
#146
Congratulations on progress to date!! Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#147
Way to go George, you're much further ahead then me.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#148
Maybe but I still have a long ways to go! After getting engine up to temp I pulled blower off so I can retorque the heads tomorrow after that I wil reinstall the blower then go over the valve lash and take a compression test then install new plugs.
GTO George |
#149
Me too. My engine sits in pieces in my garage while I'm elsewhere hiding from the heat (and the coronavirus) Jim
#150
Final got my engine squared away, had to tweak the carbs and replace the blower gasket, also installed new plugs and retimed it. Had my wife help with putting the front clip on the car....tomorrow I’ll load it on the trailer!
GTO George |
#151
Got her blown ride done?
#152
Cars loaded up and ready to go racing!
Quick 8 here I come! GTO George |
#153
Damn, George, at first glance I thought you had put a Birdcatcher on there!!
Good luck in the Quick Eight. Jim
#154
By the way, how many seven-second Pontiacs are hauled around on open trailers??? I know of at least two now.
Jim
#155
I suppose I could make that three. My lakester ran 7 seconds on a tenth-mile strip, and will also ride on an open trailer.
The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
#156
Well I lost 2nd round of eliminations (bracket race), but I did qualify at no.5 for the quick 8!
My numbers weren’t great but I haven’t touched a thing on it on 4 passes......I’ll take the small wins!! FYI it was 97 degrees out......hot! GTO George |
#157
Without a time slip or a video it never happened. Stan
#158
TRUTH^^ LOL!
My Half AN Injun..... |
#159
Also have video! GTO George |
#160
Another 90 plus degree day!
GTO George |
Closed Thread |
