#61
Yes, I understand your point now. Your use of the "semi-gloss" term concerned me, since my chart does say "flat(suede)", in that way. Some dash parts are semi-gloss, but not that forward upper dash metal. But you're right, I forgot about the textured surface that the paint additive you mentioned creates and I would not know how to replicate that with urethane paint, at this time(other than spraying it a little dry, intentionally creating some fine orange peel ).
Thanks for pointing out that it may still be available from PPG in a lacquer mix. Once again, that would be a nice detail for originality. I believe a flat finish would still be serviceable though, if someone was not as particular. |
#62
My Progress
Hello everyone,
Been busy this summer, (family, vacations, home projects) so have not had a lot of time for the car, I did get all the old trunk out. It was a PITA to get out all those spotweld.
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
#63
More Pics
I then test fitted the new trunk. I was very impressed with this dynacorn sheet metal, It just dropped right into place.
#64
More Pics
After test fitting new sheet metal, took trunk back out for Blasting and repair work on frame rails
#65
more pics.
Here are the repairs I have to make before welding trunk into car.
#66
More progress
Well here is my frame after repair and paint.
#67
More
And here is the new trunk after I drilled holes into it so I could weld it into the car. Felt kinda awkward drilling holes into my brand new trunk
#68
Painted trunk, Used weld thru primer in welding areas, thats why it looks funny.
#69
Well, I started welding trunk into car, heres a couple more pictures, tell me what you guys think so far?
#70
keep up the good work |
#71
Looks Awesome! great job!
#72
Updated Pics
Here are some pics of underneath of trunk.
#73
I drew up some center trunk brackets with my favorite drawing program, Then I laser cut them out with an industrial laser, Then I bent them up with a press brake. The trunk brackets turned out great, Just like the originals, Here are some pictures of them, they get mounted in the center section of the trunk, The outside ones were on the trunk when I got it. I did show these brackets to a few people at TA Nationals, I think I'm going to make some other parts also since I have the resources.
#74
looking good,real good.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
#75
Welded inner tail pan to trunk also. See picture of old trunk piece and how new trunk lined up almost the same.
#76
Blasted parts and door jam.
#77
After welding in some holes. Then I applied some epoxy primer to keep from rusting again.
#78
Then I put the drivers door shell back on car so I have a reference for doing the LH quarter panel. As you can see door has lots of small dings, but was not rusty, I bought it from a guy in Arizona.
#79
I have now started on the LH quarter panel, Here is the before pictues.
#80
And here are some pictures of this weeks work, I have cut off the outer wheel house. Need to blast and primer everything. Also as you can see my trunk dropoff is qustionable as weather I should use it or not. I know these are impossible to find, might just have to fix what I have on the car.
