#41
Since this came up to the top again - the book is Chevrolet Power page 154 on the racing 90 degree V6 "The GM Motorsports Technology Group has developed a lubrication system modification that improves rod oiling at high speeds. this modification is highly recommended for V6/90 engines that are operated for sustained periods above 7500" "slot 0.150 wide and 0.150 deep" Modify the upper main bearing inserts by drilling two equally spaced 1/8" oil feed holes on both sides of the original oil hole making 5 holes in each upper bearing half"
#42
Looks like I am going to have to be VERY careful with a cutoff wheel. I will have to use a very small diameter/worn out wheel too.
The pic shows the grove to the one side. Should it be done like this or does doing both sides have merit ? |
#43
The Chevy blocks they did both sides about the same.
#44
What about trying to drill a series of side by side holes and then use a small burr to connect the holes making a grove?
My Half AN Injun..... |
#45
I would copy what BES did. Its proven way... Only one side
#46
I took Tom Kilroy's engine apart no real trick oiling mods Luhne oil pump coated bearings 2 seasons racing I think 140 runs looked like the day I put it together made just under 1000 hp
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
#47
What's he revving it to Richie?
#48
7800 8000
#49
Dremel cutoff wheels come thick or thin....plus various burrs, routers and such. Suggest a good variable speed type. Also Dremel has drill type chucks available instead of using collets. Handy tool to have around.
#50
could make a fixture that bolts to the main web where you want the groove,that has the groove shape in it. would work as a guild to help not to mess up , because chances are there will be a slip or 2 ...
#51
I would use a double cut ball file chucked up in a 90 degree dotco.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#52
X2 on the small ball cut Burr!
#53
If you see Tony's stuff, it is obvious that they do it by hand, but that being said, they probably have had a lot of practice.
I am partial to copying the concept but having tools do the work consistently on each main saddle, (all the same). Whether it makes any difference? Who would know? (if the "fix" takes care of the oiling issue and the engine runs great with either method). Tom V.
#54
Cut a slot in an old bearing and practice on an old block. Practice until you are confident in the outcome. Doesn't look to hard to duplicate. I wonder how the bearings were cut in the other pictures, they looked like they were done on a machine.
#55
Just thinking
Watcha think? Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
#56
We did "oil surveys" on our research engines at work. Lots and lots of pressure taps and lot and lots of Thermocouples to read the temps. Mapped each new engine. Roush typically did the work (actually testing the engine on a dyno) as using Research Engine Dynos was way too expensive to be running that kind of test. Deal is as you change the pressure in the engine, the "Orifices" change in flow value so at the end of the day you size the oil flow holes for the best overall deal you can work out over the oil pressure/flow range of the engine. Hope that helps. Tom V.
#57
Use cut off wheels all the time. I have a 1/8" electric at the house that should do the trick. |
#58
GOFAST can do his bearing mod for around 150$. So thats another option.
#59
Always wondered if there was a specific crank oil this better for feeding things?
#60
Someone mentioned this again, so I brought it back up. I like GOFASTs option. Think I am doing that. Looks like it does the same thing and you don't have to cut into you block.
