Old 05-24-2020, 04:17 PM
56Chieftain 56Chieftain is offline
Default 1956 Pontiac water pump kit??
Do they sell such a thing as a water pump rebuild kit for the 317 engine? Or just whole rebuild pumps?
John
Old 05-24-2020, 05:34 PM
moneypit's Avatar
moneypit moneypit is offline
I just did the pump on my 56. I bought one from O'riley Auto parts. Several sources out there, I think mine was around $60.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
Old 05-24-2020, 05:43 PM
Thanks I'll check it out. John
Old 05-25-2020, 01:42 PM
Tried O'riley's but didn't find anything for a 1956 Pontiac 317.
Old 05-25-2020, 02:09 PM
Bill Hanlon's Avatar
According to Pontiac Master Parts Catalog dated 1960 and 1966 all Pontiac V8s from 1955 through 1962 (and a few newer ones) used the same water pump, part # 540069. While they don't have it listed for 1956 Pontiacs, RockAuto does have one for '62 Pontiacs here: https://www.rockauto.com/en/moreinfo...350852&jsn=431
Don't fall into the trap of "reverse rotation" listed on some of these pumps.
Old 05-25-2020, 02:31 PM
moneypit's Avatar
What engine do you have? I thought there was only one. Some vendors refer to it as a 316 and some a 317.
85 CJ7 Laredo
Old 05-25-2020, 09:01 PM
Poncho60 Poncho60 is offline
Since the 4 bolt pumps are all the same, doesn't matter. But there is only one size 1956 motor...pick whichever size you prefer.
Old 05-25-2020, 11:31 PM
https://www.oreillyauto.com/detail/b...ter+pump&pos=0
Old 05-27-2020, 12:39 AM
It's a 316.6 cid so call it what you want.
Old 05-30-2020, 12:43 PM
Thanks for the link to the page. Yeah I have seen parts places list the engines as 317 and some as 316. I usually go with 316 myself. John
Old 05-30-2020, 12:45 PM
As a follow up. Can the two short hoses to each side of the water pump be replaced without removing the assembly from the car? Seems like it is a pretty tight fit to get the hoses worked in to place. Where do you guys get the hose from?
John
Old 05-30-2020, 11:34 PM
It is easiest to remove the elbow from each head if you plan to replace the hoses. A gazillion years ago when I replaced those hoses on my 347 I just took an elbow to FLAPS and found a piece of hose to fit. One hose and a sharp knife produced a hose for each head.
Old 05-31-2020, 02:22 PM
flat-bill flat-bill is offline
Default water pump kit
I converted a regular aluminum 11 bolt long pump to an early '69 short pump. I was able to get a really reasonable kit from John the water pump guy. I think he also does fuel pumps. I think he's in Florida.
John, 813 713 5820. Great guy and knows his stuff. Billk
Old 05-31-2020, 02:24 PM
I came across his web page.
https://cowboyjohnsautoparts.com/contact-us.html
