Old 06-10-2020, 10:40 PM
Joe's Garage Joe's Garage is offline
Default What if you drained the oil and the fuel and flip the engine upside-down ?
Presuming that if you loosen the rocker nuts up so that they're only attached by a thread or so but do not remove them, the lifters would be up (down, when the engine is upside-down) enough to clear the camshaft lobes.
Just thinking outside the box.......
Old 06-11-2020, 01:54 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Clever!
Old 06-11-2020, 08:02 AM
Gary H's Avatar
Gary H Gary H is offline
This should work on a engine stand but it would make mess even if you drained the oil and water from the engine. The residual would spill out. On a dyno you'd have to disconnect it from the dyno before flipping it upside down, then place it on a engine stand to turn it.
I think it would be more work than just going ahead and removing the intake and valley pan
Old 06-16-2020, 03:14 PM
Dave Bisschop's Avatar
Dave Bisschop Dave Bisschop is offline
I've done a bunch of cams swaps on the dyno, I bent up 8 pieces of bailing wire with a hook on one end to pull up the link bar and then wrapped the other end around a rocker stud to hold it in place. I used a BOP belt drive with a remote waterpump which made the front side super easy. I had it down to an hour and half from shutting the engine off to firing back up with a different cam!
Old 06-16-2020, 04:57 PM
slowbird's Avatar
slowbird slowbird is offline
Cool! Thanks for posting
