Old 06-04-2020, 08:43 PM
grd777 grd777 is offline
Default need advice to help fix my a/c on my turbo
working on my 81 t/a turbo . i recharge the system and the clutch works , no leaks ( i think). the fans seems like is is working ,but very little air blows thru the vents and not very cold , were and what should i check first
Old 06-05-2020, 02:37 AM
Brian Baker's Avatar
When you recharged it, did you replace the drier, orifice tube and pull a vacuum on it first?
Air not being cold could be a clogged orifice tube (happened to me twice on two separate vehicles). Air not moving at all is either the fan or the ductwork.
Old 06-05-2020, 06:27 AM
fan seems to be working but something is restricting it from full blowing the air ,and all the duckwork is in place .
which one is the orifice tube
Old 06-05-2020, 09:19 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Does the fan actually change speed? The resistors can go bad and you have just one blower speed.
Can you hear the door opening/closing when you go from defrost to Max? sometimes the vacuum lines come off or on my 81 the little plastic piece attaching the cable to the door had broken luckily I found one in a wrecking yard back then.
Skip Fix
Old 06-07-2020, 10:29 PM
i do not hear the door opening . what does the flap in the cowl do . it seems not to close
Old 06-08-2020, 03:27 PM
Skip Fix's Avatar
The flap in the cowl kind of hangs open most of the time, might shut when oin max. There is a door in the box under the dash that does most of the directing. I have had to replace the resistor before.
Skip Fix
