Scott,
Don't know if these are the heads that you have. Quote:
Is that a quote from Alex/Warped? If so that sounds like what I was told they flow, and that is the cam specs I have.
Scott,
Yes. Just somethings I have saved on my disk. Quote:
Cool, thanks Stan. I dont think it will make that much power, if I could manage to get close ( minus the compression loss % ) that will be very cool for me.
I could be happy making that kind of power. I almost had Bill anderson do a set of CV heads for me a little over a year ago but a divorce got in the way. That being over, it's time to revisit a new set of either CV's or a set of 430 cfm HP's.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Jack...I feel ya on the divorce delay, mine sidelined my car for 6 years. Hope you get back to it. Hard to go wrong with a good set of highports but if CV1s are available I would go with them just to be a little diferent. 😁
It will definately be one or the other. I have a set of HP's now that I will need to move before I upgrade. Plus a chassis to finish so I have something to put the motor in!
I talked to Jim today, he is going to get me a couple missing pieces. I'm Missing a pushrod guide plate, and the shim kit for the shaft rockers along with set up instructions. Looking at one of these type housing to make the water connection from the heads.
http://marcellamanifoldsinc.com/ I don’t know if this helps you any. Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
Damn he makes nice pieces!
I agree, and say he is one of the best!
Picture shows his water manifold. I'm lucky to say that John has his craftsmanship on a big portion of my engine.
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph |
Another source for thermostat housings. http://www.precisionautomotivespecia...Manifolds.html |
That car/engine looks gorgeous. Can you tell us more about it ? What is the engine combo ?
Got busy today, I was leaning towards one of the remote style adaptors and using #10 lines from the front and back of the heads, but then would have had issues with temp sending unit too. This I believe this will be my solutions for the water crossover. I cut the bottom off along with the bypass portion. I have been plugging the water bypass to the timing cover for years anyway. Now I need to take it somewhere to have a bottom plate welded into the opening. Hoping it doesnt warp out of shape . it will work as long as long as it doesnt get deformed from the welding.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
Just and update. I had the intake in my hands again today, looks like it probably was cut apart and welded back together.
If you're worried about warpage make a jig for it out of 1/4" plate.
Looks great. Most would have gotten another valley pan.. I like it..
My Half AN Injun..... |
#38
I can make a jig. Good idea. Thanks.
#39
Took the rotating assemble to get balanced, should get it back next week. I fitted a plate to have welded in, to close off the bottom or the crossover and took it to get welded in. I should get it back tomorrow. And i made a fuel pump block off plate, with fins to go with the valley cover.
#40
