Looks great . I'm waiting for my pan from them also.
Sent from my SM-N975U1 using Tapatalk |
Street pan or race pan ?
10 qt pan for my jet boat. Just talked to Stan it's going to ship Monday. Still waiting for my 535 short block so I'm putting my High port headed 490.
Would love to see some pictures of your jet boat and more info about the engine and drive. Start a new thread?
I'll do that.
Just curious.....what does a pan like this cost?
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
FYI be carful using THE RIGHT STUFF -- if you use to much you will have to NUKE the pan to get it off , It is hell for strong and will bend a pan taking it off --
The Following User Says Thank You to cgeise For This Useful Post: | ||
800$, pickup is another 50 or so. But I am making my own.
I used The Right Stuff on my 9" housing. I had to use a come along and a big dead blow hammer. Never again. |
I agree about the Right Stuff being over kill. But if you ever did run into the problem of getting a pan off or anything for that matter. A spackel knife and a hammer will cut through it like butter. It makes it a breeze believe it or not.. Just use the corner of the knife and go in on an angle..
My Half AN Injun..... |
that should be interesting
It is easier to fool a man than it is to convince he has been fooled |
What is so interesting about a pickup ? Since it has a larger tube it will be better than any stock or Canton type or any other one that uses that small tube with tight bend.
Really not much too it. |
Adding a scrapper to this pan.
Permatex "Ultra grey" FTW
6.98 @ 199mph 4.53 @ 164mph |
Enlightening
Dragncar, how are things going on the build? The pan is for your stock block hp headed engine correct?
Shortblock is together, cam degree,d. Stopped working on it after I went to graveyard shift and it made it hard to get anything done. Terrible shift. Back on swing with a raise so I am working on it again. Car was not ready anyway, changes need to be made. (mid plate, V pump ect.) so the drag season was not going to happen. Heads are ready to go, intake needs a little milled off as I took .030 off the 80cc High Ports. Have a sweet custom 1050 built for the engine. New set of 2" Mad Dog headers. Putting a 02 bung in them. I put the thread back up just to show someone else a pic of the pan. Steffs is sending me a bolt in crank scrapper for free. Bolts on 1 1/2" below the pan rail. Then I Johnson is making me a Teflon scrapper that is going on the pan rail. Never head of anyone running 2 types of scrappers before but it looks like I am going to try it. |
