Old 06-19-2020, 05:52 AM
fbd73's Avatar
fbd73 fbd73 is offline
Default Hood hinges
Hi All,
I have a question. My car is in the paintshop and they put the hood hinges back on are trying to close the hood and have said that the right hand one now needs replacing because there is too much play in it. The hood now sits higher on the right hand side and they say they can't adjust it down any further. The hood opened and closed properly before the car went in so I don't understand why there is a problem now.
What are your thoughts?
Old 06-19-2020, 10:10 AM
78w72 78w72 is offline
the hood hinge didnt just magically go bad sitting in the shop, they dont have it adjusted right or they damaged/tweaked it when removing or installing it.
i found that the rear of the hinge needs to be adjusted all the way down while the front slot can be up more. its a balancing act, but if it fit right before they removed it, it should fit right again.
Old 06-19-2020, 01:10 PM
Formulabruce's Avatar
test it by putting a washer in the FRONT bolt area under the hinge to reverse cantilever the hinge, see if it sits down better. ( on the hood part )Also I have had to elongate the mounting slots "Up" To allow hinge to drop down more after a fender is re installed and aligned.
Old 06-19-2020, 04:58 PM
Aus78Formula Aus78Formula is offline
Lift the rear of the hinge to make the rear of the hood sit down. Plus, quite possible the hinge is worn out too.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 06-19-2020, 06:44 PM
My body shop said the same thing about my RH hinge - they were right.
I rebuilt it with bronze flanged sleeves and bolts. Works excellent now.
I just disassembled my Lemans hinges - more play in the RH than left - I wonder why?
Old 06-21-2020, 08:31 AM
FunctionalShaker FunctionalShaker is offline
If you pull the spring off, you can easily tell if there is any play in the rivets. Takes about 200 lbs to stretch them enough to remove.
Old 06-21-2020, 09:00 AM
I think if they are even questionable it is probably as good as assuming they are, springs are good things to avoid playing with wherever they are on a car!
Old 06-21-2020, 02:50 PM
Not hard if you know how to do things safely.
Old 06-21-2020, 09:10 PM
Didn't say it was hard, but many on these forums don't have the experience or correct tools but still want to attempt things.
Old 06-21-2020, 09:42 PM
fbd73's Avatar
That's exactly why I put this post up. I don't have the knowledge, so I put it out there to help me sort out the problems.
Thanks for everyone's input.
The paintshop has taken all the comments onboard and now has the hood sitting heaps better.
Old 06-21-2020, 09:44 PM
All good, wasn't referring to you in particular or this thread, just generally. Good news on the hood.
Old 06-22-2020, 03:21 PM
One learns by doing. Glad it worked out for you.
Old 06-22-2020, 03:47 PM
so was the hinge bad?
Old 06-22-2020, 06:18 PM
fbd73's Avatar
I haven't seen it personally yet but the guy said there is still more movement in the right hand hinge than the left hand hinge but the hood is sitting heaps better. When I can, I will head over and have a look.
Old 06-24-2020, 05:54 PM
fbd73's Avatar
I spoke to the guy yesterday and he said the hood is now sitting correctly. He mentioned that the comments you guys had given had really helped and he had worked through it with those in mind.
So, thanks heaps everyone and it just shows that these forums really work.
