Old 06-19-2020, 06:02 PM
694.1 694.1 is offline
Default Mini windage trays, upgrades?
This little guy is from a '57 or so.
Is there any street advantage to using a full size from a later engine?
Would a later one bolt up?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 06-19-2020, 06:37 PM
Bill Hanlon's Avatar
If you did, don't forget to mount the tube that the dipstick runs through. It goes between the block and the baffle. At the block end it slips over the short dipstick tube that goes through the block.
Old 06-19-2020, 06:54 PM
PontiacJim1959 PontiacJim1959 is offline
I would not swap out to something newer. The longer tray would require additional means to bolt it up to the main caps. For a street engine, what you have is fine unless you plan on spinning high RPM's all the time.
Old 06-23-2020, 01:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
...Would a later one bolt up?
I'm thinking that the front part of the early pan doesn't have enough room for a later tray. But I may be remembering wrong.
