Old 06-25-2020, 11:50 AM
mgarblik mgarblik is offline
Originally Posted by BADDTA View Post
Mike, that’s the saddle.
Brian
Oh, I see! I saw the aluminum look and assumed it was the bearing. Then I realized an aluminum block, DUH. So is the bearing then fed through a series of holes in the bearing or an elongated slot such as the FM bearings? Looks like a fancy set-up for sure. No doubt the Pontiac oiling system needs help in this area.
Different ways to attack the problem.
Old 06-25-2020, 08:48 PM
chiefbigb chiefbigb is offline
The bearing has 2 extra holes in it about 5/8 of a inch from the center hole. Other than that pretty much a stock bearing.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 07-04-2020, 07:11 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Thumbs up
Looking Good. Like the slot in the main saddle. I also have an IA2 aluminum block. I didn't do that particular mod,however I did open up the transition hole in the block and the FM bearing hole size is bigger in the middle.
Old 09-14-2022, 12:11 PM
Update on 71 project
ID:	598595   Click image for larger version
ID:	598596   Click image for larger version
Old 09-14-2022, 01:18 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Looking good!
Go fast, see Elvis!
Old 09-14-2022, 06:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I'd leave the Camaro body panels on and watch the puzzled looks when they are looking at the motor!
i have an old Chevy power book that shows similar mods for the racing aluminum V6/90 Bow tie block. Although the whole saddle is slotted .150 wide .150 deep and they recommend two 1/8 holes on each side of the normal bearing hole-5 holes. recommended if sustained periods of over 7500 rpm.
Skip Fix
Old 09-14-2022, 08:25 PM
That car is Marty s twin turbo 71 GTO. Making it a stick suspension class car
Old 09-14-2022, 11:38 PM
slowbird's Avatar
slowbird slowbird is offline
Very cool, nice work
Old 09-15-2022, 08:56 AM
Thanks. I'm fortunate to know Chris Accors who in my opinion is one of the best radial tire chassis men on the planet. That rear is actually for a mustang.
Old 09-16-2022, 12:37 AM
Dragncar Dragncar is offline
You have quite the shop there,
Old 10-22-2022, 09:05 AM
Back on tires
The Following User Says Thank You to chiefbigb For This Useful Post:
Old 10-22-2022, 11:03 AM
Tom Vaught's Avatar
Boost Engineer
You did well buying Mary's car. (Marty's wife).
The car was a car that they owned for a LONG, LONG time and was well cared for.
Tom V.
Old 10-22-2022, 11:18 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Insanely cool car and really nice shop
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 10-22-2022, 12:39 PM
PAUL K's Avatar
Originally Posted by chiefbigb View Post
Back on tires
Huge improvement!
Go fast, see Elvis!
Old 10-22-2022, 02:22 PM
R 70 Judge's Avatar
Back on tires
Very cool and well built car. I had to make a choice between buying Marty’s GTO and my 70 TA. I chose the TA just because I’ve always wanted a 70-72 TA. It’s nice to see it being updated. The wheels look great!
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 10-22-2022, 03:38 PM
I appreciate all the kind comments. Best way to explain where the car was 9 second back side and 7 second up front. Marty street drove the car and there was no point in doing what I have done. He had a tune in the car that made it drivable like that. He has been a great man to deal with and is interested in seeing where it goes from here. I will update on this as things move forward. Working on 2 cars at one time is a terrible idea. Never do this lol
