Old 03-27-2012, 10:02 AM
Default 1978 Sunbird Wagon
1978 Sunbird Wagon
by cammerjeff » Mon Mar 26, 2012 9:33 am
Selling my 1978 Sunbird Wagon, Originally From Northern California, original 231 V-6 Auto car. Now Has Original Short Block with 85,000 miles, Ported "high Port" Heads, Holley 4bbl Intake, Q-jet Carb, Hooker Heraders, True Duel exhaust with Manual cut outs, Rebuilt 200R4 Trans with Shift kit, and 1800 RPM Stall Converter with B&M Lock up controller, 7.5" rear axle with CV 3.73 rear gears and auburn Posi Unit. Spoon Adjustable Rear Panhard Bar, V-8 Monza Front and rear Sway Bars, Aluminum Rear Brake Drums, The car runs High 14's in the 1/4, and should be a low 14 second car with a converter with more stall.
Car has 13" Snow flake wheels and Cooper coba tires, original Paint exept for the Lt fron Fender, and drivers door that look to have been repainted years ago due to collision repair. The Car in Chesterfield Brown with a Camel Interior. Tilt Column with Formula Steering Wheel. Interior could use new Carpet, and the drivers seat is starting to split along the seams, but otherwise in good shape, I have maney spare parts that come along with it, including a 252 Buick V-6 Block & Crank, Baffled Kenne Bell Oil Pan, Bettter interion rear Side Panels, and a Passenger side Fender with No rust to replace the only spot of Rust thru that I am aware of, a 2" rust hole in that fender behind the front wheel well. More Picture on request. I also have both 26 and 28 Spline S-10 Axles, S-10 Front Spindles (NOS) and Bob Gumme Ball Joint adaptor Sleeves. And additional V-6 Buick Parts, including stock and Kenne Bell 4 bbl intakes.
Includes PHS info Packet. More Pictures On request
The car currently has 1976 Astre Grills, but I have the original 77/78 grills and turn signals.
Open to offers without the spare Parts.
Asking $3500.00
ID:	279632   Click image for larger version
ID:	279633   Click image for larger version
Old 03-27-2012, 10:23 AM
455Grandville's Avatar
455Grandville 455Grandville is offline
Niiiiiiiiiiiice
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘22 Toyota Sequoia V8
‘23 Lexus LS500 awd
‘95 Ford F-super duty 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles.
Old 03-30-2012, 07:12 AM
Thanks Brad, Now I just need someone to like a Fun Odd Ball Pontiac!!!!! for not alot of Money. And it is RWD in case any one is interested. Open to Offers without all the spare Parts.
Old 04-01-2012, 09:54 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Hum.. I'm intrested looking for money atm. Whould the car make it driving from MI to Texas?
Try calling CRUSHPROOF! 512-386-9889
Old 04-02-2012, 07:32 AM
It should, I have driven it with no issues for 500 miles one way, but that is the farthest I have driven it. The engine uses a little oil, so you would have to check that every fill up, and probably add a qt every other fill up. Travels 70 MPH on the highway at 2800 rpm and gets around 20 MPG cruising.
Old 08-16-2021, 11:36 PM
77 Astre GT 77 Astre GT is offline
Jeff, have you sold the Sunbird yet?
This is Shawn, I am still interested in finalizing the sale. Please contact me at seddie21@gmail.com.
Old 08-17-2021, 12:27 PM
Email sent
Old 10-21-2021, 10:24 PM
Sold!
