Old 07-17-2019, 04:19 PM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
Default New firewall pad installation 77 T/A ?
Would you use the old rubber retainers or the plastic ones that come with a new one?
My old rubber ones are still good.77 trans am.
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
Old 07-17-2019, 05:07 PM
70GS455 70GS455 is offline
Old ones if good. The repo ones flex and bend too much and are hard to get thru the hole
Sent from my SM-T817V using Tapatalk
Old 07-17-2019, 06:14 PM
yes,old are good,not hard after 42 years!
Old 07-17-2019, 06:29 PM
unruhjonny's Avatar
on a related note, was there fibreglass(?) sections inserted into the ends of the firewall?
I pulled out a tattered chunk of fibreglass from mine;
the day after tossing it, I thought to myself maybe it was put there from the factory, so I pulled it out of the garbage, and pieced it together for a picture.
1970 Formula 400
Old 07-17-2019, 06:53 PM
not on this car.
Old 07-17-2019, 07:41 PM
unruhjonny's Avatar
maybe someone else can tell me what this is about(?)
1970 Formula 400
Old 07-18-2019, 04:00 PM
I think that is what is glued to the underside of the dash top surface. They make a replacement
Old 07-18-2019, 04:10 PM
unruhjonny's Avatar
I have rust in the usual spot of the bottom corners of the firewall - visable when fenders are removed - infront of, and below the hings mounts;
I pulled this out of the little hole there.
So unless I have grossly misunderstood you, I don't know if "dash" is applicable...
Thanks for offering your suggestion though.
I'll keep this chalked up as a mystery...
1970 Formula 400
