Old 06-17-2019, 01:40 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
Default Metal Firebird emblem to cover window crank hole
When did they stop using the pot metal Firebird emblem that covers the window crank hole.
All the NOS ones I’ve seen on Ebay look plastic.
Does anyone make a metal reproduction one?
Old 06-17-2019, 02:56 AM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
I'm thinking 74....was last year for metal......
I haven't seen any metal repro's.....just plastic...
Old 06-17-2019, 09:29 AM
I’ve seen metal ones on 73’s and I’ve seen plastic ones on 73’s both original owner cars .
Old 06-17-2019, 10:27 AM
HO Kenny's Avatar
This may not be the correct place for this, but, does any have a spare metal one they would be willing to part with?
Old 06-19-2019, 08:55 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
I think the part number was an early 1970 Car only part number. Superseded in late 70 by the plastic one. Every early 1970 bird I have seen will have the cast metal window crank covers. They are rare. I have not seen these on 71 and up cars that are original. Have seen these on later cars that someone bought or found some and swapped. They are nice. I have an NOS set for my early 70 TA. Just my observation.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 06-19-2019, 10:27 AM
They were definitely used till 73...at least.....
Early production 70's with power windows.......had NO hole in door panel....for crank...or emblem....
Old 06-19-2019, 11:14 AM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
this sounds to me to be correct.
1970 Formula 400
Old 06-20-2019, 10:15 AM
bird72's Avatar
bird72 bird72 is offline
I have one that needs TLC. I think they have 3 posts on back, two on top, one on bottom? The bottom one is broke off on mine. The bird silver is wore, but I think they are the same as dash panel bird and if repo'd could be changed. Or silver re-lined to edges on this one.
you are welcome to it, not sure it is better than none
72 Bird
Old 06-20-2019, 11:11 AM
unruhjonny's Avatar
Ken - there /\ /\ is your answer!
1970 Formula 400
Old 06-21-2019, 09:54 AM
HO Kenny's Avatar
Mine has a screw though it so that’s an offer I can’t refuse.
Anthony I Sent you a PM.
Old 06-21-2019, 11:14 AM
77 Canamman's Avatar
Just curious..Does anyone have a pic of one of these, or do they appear the same as the later plastic versions?
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 06-21-2019, 11:35 AM
HO Kenny's Avatar
Pics of the one without the screw and a plastic one.
The biggest differences other than weight is the outer rim is machined and wider than the plastic one and the pebble grain background is slightly different.
ID:	514566   Click image for larger version
Old 06-21-2019, 06:48 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Here's a pair on ebay.
https://www.ebay.com/itm/1970-1981-F...temCondition=4
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
Old 06-21-2019, 07:04 PM
unruhjonny's Avatar
I'm pretty sure those are the latter plastic ones.
1970 Formula 400
